Need to know what happens with dsl line after 675 looses the connection..
Does 675 try to re-connect?
Does ADSL line connect fine?
Does dsl/atm LED flashing after that?
It will be more helpful if you connect a console cable to 675 and issue some show commands once 675 loses the connection . Like
sh run
show int wan0-0
show dsl int wan0-0
Try adding following command "set ppp retry 3" in the config and after that issue "write" and "reboot" (as config changed) and moniter it..
