cisco nexus 2148T power slots
Mahmoud93
i have two power supplies and both are lighting green but on cli i can find that the slot 2 in shut , i cannot determine which one is lot 2 since there is no label beside them. is it from left to right always
marce1000
            Yes, usually from left to right.
 M.
Sergiu.Daniluk
Hi @Mahmoud93
@marce1000 already answered your question - yes the left PSU is the PSU1 and the right one is PSU2.
What I want to add is if the LED is green, most likely you are encountering a bug. Ofc, reseating the PSU is the first action step in the troubleshooting, but if that does not fix the problem, I would suggest a FEX reload (which is not always an easy thing to do).
Stay safe,
Sergiu
Hi @sergiu
Thank you for your recommendation, we have replaced it but the cli still shows hat there is a failure , so we did reboot for the FEX and it works.
Javier Acuña
Hola, espero te encuentres bien  por lo general la Fuente PSU1 es la del lado izquierdo la y la PSU2 es la del lado derecho a continuación comparto imagen referencialNEXUS 2000.PNG
Recuerda calificar esta respuesta ya que esto motiva a continuar respondiendo.
Saludos.
