CISCO-POP-MGMP-MIB doesn't works
kurlas
i have one Cisco3620 router with one 8 ISDN Basic Rate interface, and version 12.2(6) IOS. The router is properly configured for ISDN dial-in users, and i want to monitor the active calls with MRTG, or RRDTools via SNMP queries.
I red about interested CISCO-POP-MGMP-MIB entries from Cisco's Dial NMS implementation guide, and when try to use these, the answer is:
$snmpwalk 10.1.0.1 drvread .1.3.6.1.4.1.9.10.19
enterprises.9.10.19.1.1.2.0 = Gauge32: 0
enterprises.9.10.19.1.1.3.0 = Gauge32: 0
enterprises.9.10.19.1.1.4.0 = Gauge32: 0
enterprises.9.10.19.1.1.5.0 = Gauge32: 0
enterprises.9.10.19.1.1.6.0 = Gauge32: 0
enterprises.9.10.19.1.1.7.0 = Gauge32: 0
enterprises.9.10.19.1.1.8.0 = Counter32: 0
enterprises.9.10.19.1.1.10.0 = Gauge32: 0
enterprises.9.10.19.1.1.11.0 = Gauge32: 0
enterprises.9.10.19.1.1.12.0 = Gauge32: 0
enterprises.9.10.19.1.2.1.0 = Counter32: 0
enterprises.9.10.19.1.2.2.0 = Counter32: 0
enterprises.9.10.19.1.2.3.0 = Counter32: 0
enterprises.9.10.19.1.2.4.0 = Counter32: 0
enterprises.9.10.19.1.2.5.0 = Counter32: 0
enterprises.9.10.19.1.2.6.0 = Counter32: 0
enterprises.9.10.19.1.4.1.0 = 100
enterprises.9.10.19.1.4.2.0 = 15
enterprises.9.10.19.1.5.1.0 = 2
enterprises.9.10.19.1.6.1.0 = 2
Can I somehow monitor the active call's with SNMP from 3620, or this works only with 5xxx ASs? Why doesn't work the mentioned MIB?
Best regards,
Qrta
----------o<------------
and the answare was:
mljohnson - CISCO SYSTEMS, CCIE
Oct 24, 2002, 11:22am PST
Yes, this should be supported by the 3620:
http://www.cisco.com/public/sw-center/netmgmt/cmtk/mibs.shtml
MRTG should not be a problem, either:
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/dialsol/nmssol/mrtg.htm
You may want to try the Network Management group for more help.
So, works the MIB, or not?
Best regards,
Qrta
rmushtaq
Level 8
Level 8
Do you have the IOS image name available running on this 3620 as seen in the 'sh ver' output?
the show ver is:
IOS (tm) 3600 Software (C3620-I-M), Version 12.2(6), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Wed 07-Nov-01 19:41 by pwade
Image text-base: 0x600089A8, data-base: 0x60A60000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
drvisdn uptime is 15 weeks, 2 hours, 1 minute
System image file is "flash:c3620-i-mz.122-6.bin"
cisco 3620 (R4700) processor (revision 0x81) with 24576K/8192K bytes of memory.
Processor board ID 18045113
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
8 ISDN Basic Rate interface(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Standard IP featureset.
Best regards, Qrta
CCO MIB Locatore Tool does show that c3620-i-mz.122-6.bin have this MIB present. Have you searched CCO Bug Toolkit to see if there are any open defects related to this?
As I see only 12.2T supports this MIB? Sorry, I haven't saw that yet... I'll try it.
Thanx,
Qrta
