Ciscoworks RME admin inventory problems
Philip Nevins
I am consistently having issues with the Inventory database. There are suspended devices that I cannot delete. There are not responding devices that I cannot delete as well as pending devices that I can do nothing with at all. Is there a way to clear the inventory database at a command line leve that will clear this database out completely so that I can rebuild it. I also have tried to create an import file that I have never had any luck with. any suggestions on that?
paddyxdoyle
Level 6
Level 6
You can clear out your RME database using the following on a Solaris Platform
opt/CSCOpx/bin/perl /opt/CSCOpx/bin/dbRestoreOrig.pl dsn=rme dmprefix=Essentials npwd=*your-new-password*
I have done this in the past on a Solaris box, plus also i've flushed the ANI database too, all without any issues...
The following link shows a bit more detail on how to do this on Solaris AND Windows:
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/prod_troubleshooting_guide09186a00801d3120.html#wp1053797
Good luck
Paddy
