Commands to remove/delete BGP from interface and network neighborship
jacqcox
I'm trying to delete BGP from my environment XE or XR routers. I don't know what command to use to validate what is attached to BGP meaning is it configured on the interface or is there a map-route, AF. Looking
balaji.bandi
show run | sec router bgp BGP will give you all config configured on the device.
you can see the - show ip bgp neigh (output show local IP and remove IP - you can map with IP associated interface.
Some cases same IP also have different BGP peers, you need to validate that config before you delete any BGP associated config.
BB
balaji.bandi
BB
