config a frame really between one point to mutli points
atattan123
I have two routeres 3600 series and 4 of 1700's series, I want to config a static between 3600 series which has one serial port only to those 1700's routers series.
any one who can help in this issue please .
in your scenario, configure the 3600 router as the hub and the 1700 routers as the spokes. If you use the same address space on all routers, you can stay with the physical interfaces, if you require a different address space between the hub and the spokes, configure subinterfaces on the 3600 router.
I am not sure how familiar you are with the configuration details, you might want to check the link below, it has numerous sample configs:
Frame Relay
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Technologies:Frame_Relay&s=Implementation_and_Configuration#Samples_and_Tips
HTH,
GP
