11-15-2001 05:34 AM - edited 03-01-2019 07:23 PM
Hi, I've got 3 3500 switches in a GigaStack loop configuration.(3 cables)
Now I've bought 2 new 3548s.
Can I disconnect the redundant loop safely, add the GigaStack cables for the new switches and configure them using the web Cluster Management interface, without causing any problems to connected PCs?
TIA
11-15-2001 07:35 AM
just to add
Switches are a 3524XL and others are 3548XL.
One of the GigaStack port LEDS on the first switch (the 3524) is amber. Is this normal?
11-15-2001 01:38 PM
Bump...
Anybody care to comment on this one???
11-15-2001 02:26 PM
Yes, when configuring GigaStack ports in a redundant loop it is normal to have one LED amber. This indicates which port has gone into spanning-tree blocking mode in order to prevent a bridging loop. Even if you enter the global config command "no spanning-tree" the GigaStack ports will still have spanning-tree enabled. Also note that when using both ports on a GigaStack GBIC they will operate at half-duplex.
11-15-2001 03:17 PM
Thanks, interesting.
So if I had 5 switches and no redundancy then 2 of them could operate at full duplex? Do I really need the redundancy - I can't see many problems with the GBIC stuff.
Does it matter which cable I disconnect in order to 'insert' the 2 new switches? The reason I ask is because the amber connection is not the cable which is showing as the redundant link in the Cluster Manager sofware - slightly confusing...
