Configuring an E1 int. for Incoming Analogue + ISDN and Outgoing ISDN
aclrnet
Problem Description: I am looking to configure a proposed router into my network however in need confirmation that the configuration can be done.
What i am doing is this. I have an OnRamp10 connected to an CE1 port on my 3640 router. This onRamp 10 will cater for 6 analogue calls coming into it (using 6 Digital Modems), 3 ISDN incoming calls and 1 ISDN outgoing call. The question is, can a configuration be built for this OnRamp10 to cater my needs. I have looked on the Cisco web site and hav found 1 document explaining how to configure incoming Analogue and ISDN calls into a E1 service, but i cannoit find a document on all 3 tasks i need to achieve. Can anyone please help by supplying some documentation or sample configuration/tasks.
lisa.hall
Level 2
Level 2
Check this one out. This doc talks about configuring Dialin and Dialout on the Same T1/E1 PRI
http://www.cisco.com/warp/public/793/access_dial/pri_dialin_6435.html
