Connecting Router between Switch and Ethernet Port
terrythompson
I uploaded both of the router configurations I used on the 1750 router and I unable to get pass E1/0 which should put me on my companies Lan. Thanks
ankurbhasin
Level 9
Level 9
Hi Terry,
Can you explain how these 2 routers are connected to each other. Also can you tell us what is th destination you are trying to access. PLease if posible paste "sh ip route" and the destination ip you are trying to access. Also if possible the topology.
Ankur
Well I guess the best way to explain what I trying to accomplish it create my own LAN off my companies LAN
Wall Jax-------------1751 E 1/0-----------1751 FA 0/0-------------2950 Switch
Nat the 1751 Router with FA 0/0 with this interface address 192.168.3.1 /24
And E 1/0 with a static address of 192.168.2.253 or preferable use the
"ip address dhcp” Command.
