trunking Catalyst 2950 to Catalyst 3750 problem
DarylPienta
I cannot seem to figure out how to trunk a catalyst 3750 to a Catalyst 2950.
I've set
3750(config)#interface fastethernet 1/0/2
switchport mode trunk
BUT my Catalyst 2950 does not offer the "switchport trunk encapsulation dot1q" command
My 2950 is running IOS version 12.1(20)EA1a
is there a work around for this situation. Our network still employs a bunch of these 2950's.
konigl
Level 7
Level 7
The Catalyst 2950 series can only do 802.1Q trunking. It's the default, and only, choice. So there's no need to specify it when trunking.
In fact, since you don't have a choice of which encapsulation to use, there's no need for a "switchport trunk encapsulation" command. Which is why it's missing from the Cat2950 switch IOS.
This took me by surprise too, when I first transitioned out of the 3500XL series into 2950 and 3550 switches.
thisisshanky
Level 11
Level 11
Like Larry said, you dont need to enable dot1q on 2950, as it doesnt support any thing else other than dot1q. I would think all you need on the fastE interface of 2950 is "switchport mode trunk" command.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
