Connectivity issue when using Gigabit ethernet module
malberttoo
Gurus,
I have a smaller network spanning 3 buildings, only needing 1 3650 Catalyst POE switch in each building. Switch 1 and 2 are connected by a fiber connection, and switch 2 and 3 are connected by an Aeronet 1400 wireless shot.
I have 4 servers, and wanted to get them all on a Gigabit 'backbone'. My switches are all 10/100, so I bought two cisco GLC-T modules - they are Small Form Factor modules that plug into the little expansion bays on the end of the switch, thereby allowing that one port to become Gigabit ethernet.
However, I have no network connectivity when plugged into these modules, even though though the port light is green. When I telnet into the port, and do a 'show gigabitethernet 0/2' the results clearly show that there is a 1000 base T module plugged into it. I cannot access or ping anything, either when plugged directly into the module, or when plugged into a Linksys Gigabit switch, in turn plugged into the module. I have this problem with either module, on any of the three switches.
I am gratefuel for any advice you can provide.
5 Replies 5
Roberto Salazar
Level 8
Level 8
Can you post the show version of the 3560 where you plug in the GLC-T modules? Have you tried disabling the speed negotiation with "speed nonegotiate" under the interface with GLC-T?
leonvd79
Level 4
Level 4
Hello Malberttoo,
To verify if your configuration is valid use:
show version - to verify that your software code is the recommended version, as stated on the compatability chart.
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_device_support_table09186a0080446625.html
show interface Gi0/2 - look at interface statistics, is the line and link status "up"?
show idprom interface Gi0/2 - verify if the transceiver is recognized by the switch
--Leon
Bosalaza, here are the results of my Show Version:
Cisco IOS Software, C3560 Software (C3560-IPSERVICES-M), Version 12.2(25)SEB1, R
ELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 29-Apr-05 22:25 by yenanh
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEA, RELEASE SOFTWAR
E (fc)
CommRoomSwitch uptime is 6 weeks, 6 days, 4 minutes
System restarted at 19:04:02 UTC Sat Apr 29 2006
System image file is "flash:c3560-ipservices-mz.122-25.SEB1/c3560-ipservices-mz.
122-25.SEB1.bin"
cisco WS-C3560-24PS (PowerPC405) processor (revision M0) with 118784K/12280K byt
es of memory.
Processor board ID CAT0923R1BA
Last reset from power-on
2 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:14:6A:6E:0C:80
Motherboard assembly number : 73-9673-06
Power supply part number : 341-0029-03
Motherboard serial number : CAT092303KJ
Power supply serial number : DTH09206X52
Model revision number : M0
Motherboard revision number : A0
Model number : WS-C3560-24PS-E
System serial number : CAT0923R1BA
Top Assembly Part Number : 800-26380-03
Top Assembly Revision Number : A0
Version ID : V05
CLEI Code Number : COM1100ARB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C3560-24PS 12.2(25)SEB1 C3560-IPSERVICES-M
Configuration register is 0xF
I know next to nothing about configuring these switches, so I have not adjusted any settings. Should I add the command to the interface, as you have described?
Leon, the Show Interface is indeed up:
GigabitEthernet0/2 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0014.6a6e.0c82 (bia 0014.6a6e.0c82)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
input flow-control is off, output flow-control is unsupported
Last input 00:02:49, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 2000 bits/sec, 3 packets/sec
1296 packets input, 114704 bytes, 0 no buffer
Received 1143 broadcasts (0 multicast)
0 watchdog, 568 multicast, 0 pause input
57266 packets output, 4389801 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
And here is the Show IDProm:
General SFP Information
Identifier : 0x03
Connector : 0x00
Transceiver : 0x00 0x00 0x00 0x08 0x00 0x00 0x00 0x00
Encoding : 0x01
BR_Nominal : 0x0D
Vendor Name : Methode Elec.
Vendor Part Number : SP7041
Vendor Revision : 0x41 0x20 0x20 0x20
Vendor Serial Number : M820389
Thank you both very kindly for your replies!
-Michael
Try it. the interface is up/up but do not see input, how are you verifying that it's not passing traffic? Waht is the other end of this interface? Can you try assigning a vlan that is not used anywhere else on this port or making it a layer 3 port. the point of the suggestion is to use ping test to see if it's passing traffic. show interface does not show me ip address so it must be a switchport. what does show int gig 0/2 counter show? any unicast rx, mcat rx or broadcast rx?
The "nonegotiate" part of the command is unsupported on this device, it appears.
I'm verifying the lack of connectivity in no technical way, just the fact that any device plugged into one of these ports does not get a DHCP address from my server, and has no internet or network access.
Show interface...counter yields the following:
Port InOctets InUcastPkts InMcastPkts InBcastPkts
Gi0/2 99272 0 18 821
Port OutOctets OutUcastPkts OutMcastPkts OutBcastPkts
Gi0/2 239219 5 3111 0
Here is the part where my ignorance really shows, but I don't know how to put the port on an unused Vlan, or even create another Vlan for that matter.
Thanks again for your advice.
-Michael
