CPU HIGH on 3750-X, due to the processes: ARP input, Hulc LED Process, IP Input
Currently I have a problem with my cisco 3750-X switch which is registering a high CPU consumption constantly, apparently for no reason.
  This causes latency in the communication of my network. Since the switch works like CORE. The main tasks executed during this period are: ARP Input, Hulc LED Process, IP Input. I have several monitoring sensors, in which I observe that this is repeated from Monday to Friday almost all day, only on weekends is that it goes down a little and yet remains between 50-65% (on weekends nobody works in the place). Also I do not have the active debug, it has reached maximum peaks of 94% of CPU consumption.
CPU utilization for five seconds: 98%/12%; one minute: 89%; five minutes: 92%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
10 1872349464 732273732 2556 15.34% 17.28% 17.02% 0 ARP Input
198 766358309 707625913 1082 11.86% 17.36% 21.71% 0 IP Input
156 2414281375 629451023 3835 11.54% 11.62% 11.69% 0 Hulc LED Process
238 281144827 9905330 28383 8.06% 3.34% 3.03% 0 VMATM Callback
95 302130191 591397160 510 5.06% 3.31% 3.48% 0 HRPC hlfm reques
96 251050276 787319345 318 4.26% 2.30% 2.11% 0 HLFM address lea
217 833619836 39601251 21050 3.32% 2.70% 2.64% 0 Spanning Tree
8 69106100 494631 139714 2.68% 0.34% 0.22% 0 Licensing Auto U
74 804493388 140381707 5730 2.37% 2.04% 2.15% 0 RedEarth Tx Mana
116 537949262 57298213 9388 1.73% 1.68% 1.66% 0 hpm counter proc
4 398933141 17348972 22994 1.58% 1.28% 1.22% 0 Check heaps
73 154719695 213679773 724 1.42% 1.19% 1.26% 0 RedEarth I2C dri
80 367529551 11720528 31357 1.42% 1.23% 1.21% 0 Adjust Regions
83 119943458 447551373 267 1.42% 0.75% 0.72% 0 hrpc <- response
353 43412697 2416961 17961 1.26% 0.43% 0.39% 0 SpanTree Flush
Note:
I do not have ACL configured, and I work with static routes.
Firmware Version 12.2(53r)SE2
6 Replies 6
Seb Rupik
Hi there,
Wow that is some old software you are running! You are seeing this 'bug':
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtn42790/?rfs=iqvred
suggest you move to the current recommended release (15.2(4)E7)at your earliest convenience:
https://software.cisco.com/download/home/282979365/type/280805680/release/15.2.4E7
cheers,
Seb.
Leo Laohoo
That's the bootstrap version.  What is the IOS version?
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Looks like expected behaviour of the 12.2(55) train:
Either migrate to 12.2(58) (not recommended) or try the recommended 15.2(4)E7 as previously recommended.
cheers,
Seb.
Wow.  That's a pretty old firmware.
What is the uptime and how many members in a stack?
good day
The equipment is in stack (2 switches), and it has more than 50 weeks that it does not turn off, since it governs the operational continuity of the work site.
