Customization of Privilege Level to limit techs ability on switch
MARK CHRISTY
I thought I posted this question but can find no evidence of it. So forgive me if I repeat myself.
I would like to find an "examples" of setting a login user to have a limited set of functionality. I searched within IoS command refreences and discovered command "privilege exec level 10 configure". This lets a user with privilege 10 access the exec command "configure". I'm wondering how granular I can make this. I want to have a user who can go to a range of ports (or media type), and have the ability to do a "shut" - "no shut". Also setting the Vlan of a port. So far I've been marginally successful (that's actually a fail).
If anyone has any insight into or a good source of configuration examples using this feature I would appreciate if you shared your insight.
Marvin Rhoads
I don't believe you can restrict it to a range of interfaces but you can certainly allow a tech user to only configure at the interface level.
The feature is known as "role-based access control" or RBAC. A search on that will turn up some good documents. Here are a couple:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t7/feature/guide/gtclivws.html
https://www.packetmischief.ca/2015/03/13/role-based-access-control-in-ios/
http://brbccie.blogspot.my/2013/04/privilege-role-based-cli.html
Marvin Rhoads
MARK CHRISTY
Excellent examples - I achieved 99% of what I'm needing on the first look at packetmischief! Thank you very much. I'm still playing with it but enabling my Help Desk techs to change a port on a vlan, cycle PoE for a port, simple diagnosis; is just what the doctor ordered.
I'll keep using this! Thanks again.
You're welcome. Half the battle is knowing what Cisco calls it. Google usually points me to the rest of it. :)
Thanks for rating.
