DDS Problems
cabell911
Does anyone see any problem with the following config. of two 56k CSU/DSU's? Notice the high input errors on one interface. Telco. says line seems to be fine and loopback test turns out ok. I just cleared the counters but they went back up in a matter of minutes. I'm at my end on this one.....Thanks for any help.
Serial0/0 is up, line protocol is up
Hardware is PQUICC with 56k 4-wire CSU/DSU
Description: connected to Cisco2611
Internet address is 172.16.1.2/24
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input 00:00:07, output 00:00:02, output hang never
Queueing strategy: fifo
Output queue 0/40, 1 drops; input queue 0/75, 0 drops
69 packets input, 4562 bytes, 0 no buffer
Received 18 broadcasts, 0 runts, 2 giants, 0 throttles
89 input errors, 8 CRC, 60 frame, 0 overrun, 0 ignored, 21 abort
99 packets output, 7061 bytes, 0 underruns
0 output errors, 0 collisions, 13 interface resets
11 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Serial0 is up, line protocol is up
Hardware is HD64570 with 56k 4-wire CSU/DSU
Internet address is 172.16.1.1 255.255.255.0
MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec, rely 255/255, load 9/255
Encapsulation HDLC, loopback not set, keepalive set (10 sec)
Last input 0:00:00, output 0:00:00, output hang never
Last clearing of "show interface" counters 2d14
Output queue 0/40, 11 drops; input queue 0/75, 0 drops
5 minute input rate 2000 bits/sec, 3 packets/sec
5 minute output rate 2000 bits/sec, 2 packets/sec
41707 packets input, 6697640 bytes, 0 no buffer
Received 29911 broadcasts, 0 runts, 0 giants
11 input errors, 7 CRC, 0 frame, 0 overrun, 0 ignored, 7 abort
36290 packets output, 5068207 bytes, 0 underruns
0 output errors, 0 collisions, 61 interface resets, 0 restarts
114 carrier transitions
thisisshanky
Level 11
Level 11
Do you have any extended demarcs? When telco did loopback tests, did they test the SJ or at the extended demarc? was a hardware loopback used ?
Also your hardware can be tested by giving a hard loop at the router CSU/DSU port. Take a ethernet 8 wire cable and crimp a rj45 jack on one end, while at the other end, twist pins 1 and 7 together, and, pins 2 and 8 together. Now this is a hard loop. insert the rj 45 end to the router, and now the router Csu/dsu port has been looped.
Now you can do clear the interface counters, assign an ip address to the serial interface and then do extended ping tests, with varying data patterns of all 1s, all 0s and see if the errors are increasing
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Sorry it took so long to get back guys. Yes, I have done all of the loopback tests successfully and it doesnt seem to show any errors. I'm getting some TAC help on this but they are kind of slow. They seem to be leaning towards an IOS bug. Its currently 11.0(13).
JR
