Debug Result %SSSMGR-3-MEMORY_LOW
sodiqovziyod609
Hi everyone. I have a question. I work for a ISP and some days ago we faced to strange problem. Some PPPoE sessions cannot be connected. And if I will debug its mac-address, it will show this message: %SSSMGR-3-MEMORY_LOW: Memory low (2154351 times), disconnecting session.
Could somebody explain, why this message is appeared?
Than you for your response
Leo Laohoo
The router you have remote into has a memory leak and the level of free memory left is at it's most critical level.
Notify the senior on the floor.
5 Replies 5
Leo Laohoo
sodiqovziyod609
Thank you for your answer, @Leo Laohoo . And, next question, the fail of PPPoE sesions can be because of this issue?
It is a possibility but it is not for certain.
Fix the memory leak and see if the failed PPPoE sessions goes away.
BTW, @Leo Laohoo doesn't possess enough information to be certain, but low memory is bad juju for IOS operations.
Also BTW a memory leak bug often can lead low memory but some "normal" operations can too.  For the latter you need to change your operations and/or and RAM to device.
Mark Elsen
            - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtj31398
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
