debugging spanning tree
kimlong
I am looking into some lan probs and I am using the document:
Troubleshooting Spanning-Tree Protocol and Related Design Considerations
as a resource. In the section:
An Additional CatOS Command
The Catalyst specific software is richer than the IOS as far as STP troubleshooting is concerned. The command show spantree statistics <module#/port#> <vlan#> gives very accurate information on a specific port. On suspected ports, run this command and pay special attention to the fields:
Forward trans count: this counter remembers how many times a port transition from learning to forwarding. In a stable topology, this counter should always show 1. This counter is reset to 0 is the corresponding port is going down and up. So, if the value is higher than 1, it means that the transition this port experienced is the result of a STP recalculation, not of a direct link failure.
Max age expiry count: this counter tracks the number of times the max age expired on this link. Basically, a port expecting BPDUs will wait for max age (default 20 seconds) before considering its designated bridge as lost. Each time this event occurs, the counter is incremented. When the value is not zero, you know that for whatever reason, the designated bridge for this LAN is unstable or has problem transmitting its BPDUs.
I need some clarification.
To utilize the command 'show spantree stats mod/port vlan', should this
be done on the trunk ports AND only for active vlans on the switch?
OR
Should it be done on all ports for all vlans everywhere?
OR should it be don for trunks only for all vlans everywhere?
Secondly, the statement 'Max age expiry count: this counter tracks the number of times the max age expired' seems to be a typo. I can only see a 'msg age expiry count'. Clarification is needed here-is it a typo or did I miss the counter?
Thanks in advance.
8 Replies 8
milan.kulik
Level 10
Level 10
AFAIK, to utilize the command 'show spantree stats mod/port vlan', this should be done on the trunk ports AND only for active vlans.
You can try it on passive (pruned) VLANs - STP is still running, but if there are no user data passing the VLAN, it has not a big sense to check it.
If you try to issue 'show spantree stats mod/port vlanx' and VLANx is disabled on the trunk, you just receive 'Vlan x does not exist' message.
If you try to issue 'show spantree stats mod/port vlanx' on port which is not a trunk, you receive:
SpanningTree enabled for vlan = x
Invalid Port : Not part of dynamic SPT data structure.
To your secon question:
'Max age expiry count' is a typo, 'msg age expiry count' is correct.
See http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/7_5/cmd_ref/sh_s_t.htm#1026947 for details.
Milan
Thanks for your help. Along these lines using the 'show spantree
mod/port vlanx' I need some further clarification. The document says
I found a link that shows 0, not 1 or not a value higher than 1. Is this a
software bug or does it indicate a problem?
it seems like a portfast enabled port.
Portfast is skipping the listening and learning phase so there is no learning to forwarding transition to remember.
Milan
This is the config for the port:
set port channel 1/1-2 321
#module 1 : 2-port 1000BaseX Supervisor
set port trap 1/1-2 enable
set udld disable 1/2
set trunk 1/1 auto isl 1-1005
set port channel 1/1-2 mode off
I don't see anywhere that portfast is enabled. Is there something else
I should check?
try sh spantree mod/port.
It should show portfast value directly on the port.
It can be configured via several ways, set spantree global-default portfast ena, e.g.
Another idea (if portfast is not enabled): the 0 value migth be caused by the fact the port has never (since the last switch reload) gone up?
Milan
ac-sw-1> (enable) sh spant 1/1
Port Vlan Port-State Cost Priority Portfast Channel_id
1/1 1 forwarding 4 32 disabled 0
1/1 2 forwarding 4 32 disabled 0
1/1 10 forwarding 4 32 disabled 0
1/1 15 forwarding 4 32 disabled 0
1/1 17 forwarding 4 32 disabled 0
1/1 18 forwarding 4 32 disabled 0
1/1 20 forwarding 4 32 disabled 0
1/1 25 forwarding 4 32 disabled 0
1/1 26 forwarding 4 32 disabled 0
1/1 27 forwarding 4 32 disabled 0
1/1 30 forwarding 4 32 disabled 0
1/1 40 forwarding 4 32 disabled 0
1/1 50 forwarding 4 32 disabled 0
1/1 51 forwarding 4 32 disabled 0
1/1 60 forwarding 4 32 disabled 0
1/1 80 forwarding 4 32 disabled 0
1/1 91 forwarding 4 32 disabled 0
1/1 92 forwarding 4 32 disabled 0
1/1 100 forwarding 4 32 disabled 0
1/1 101 forwarding 4 32 disabled 0
1/1 102 forwarding 4 32 disabled 0
1/1 103 forwarding 4 32 disabled 0
1/1 104 forwarding 4 32 disabled 0
1/1 105 forwarding 4 32 disabled 0
1/1 106 forwarding 4 32 disabled 0
1/1 107 forwarding 4 32 disabled 0
1/1 108 forwarding 4 32 disabled 0
1/1 200 forwarding 4 32 disabled 0
1/1 201 forwarding 4 32 disabled 0
1/1 202 forwarding 4 32 disabled 0
1/1 203 forwarding 4 32 disabled 0
1/1 204 forwarding 4 32 disabled 0
1/1 205 forwarding 4 32 disabled 0
1/1 206 forwarding 4 32 disabled 0
1/1 207 forwarding 4 32 disabled 0
1/1 208 forwarding 4 32 disabled 0
1/1 209 forwarding 4 32 disabled 0
1/1 210 forwarding 4 32 disabled 0
1/1 211 forwarding 4 32 disabled 0
1/1 300 forwarding 4 32 disabled 0
1/1 301 forwarding 4 32 disabled 0
1/1 302 forwarding 4 32 disabled 0
1/1 303 forwarding 4 32 disabled 0
1/1 304 forwarding 4 32 disabled 0
1/1 306 forwarding 4 32 disabled 0
1/1 401 forwarding 4 32 disabled 0
1/1 402 forwarding 4 32 disabled 0
sh spantree stat 1/1 103
Port 1/1 VLAN 103
BPDU-related parameters
port spanning tree enabled
state forwarding
port_id 0x8001
port number 0x1
path cost 4
message age (port/VLAN) 0(20)
designated_root 00-d0-00-f8-30-66
designated_cost 0
designated_bridge 00-d0-00-f8-30-66
designated_port 0x8001
top_change_ack FALSE
config_pending FALSE
port_inconsistency none
PORT based information & statistics
config bpdu's xmitted (port/VLAN) 0(0)
config bpdu's received (port/VLAN) 0(0)
tcn bpdu's xmitted (port/VLAN) 0(0)
tcn bpdu's received (port/VLAN) 0(0)
forward trans count 0
scp failure count 0
Status of Port Timers
forward delay timer INACTIVE
forward delay timer value 0
message age timer INACTIVE
message age timer value 0
topology change timer INACTIVE
topology change timer value 0
hold timer INACTIVE
hold timer value 0
delay root port timer INACTIVE
delay root port timer value 0
delay root port timer restarted is FALSE
VLAN based information & statistics
spanningtree type ieee
spanningtree multicast address 01-80-c2-00-00-00
bridge priority 32768
bridge mac address 00-d0-00-f8-30-66
bridge hello time 2 sec
bridge forward delay 15(15) sec
topology change initiator: 1/0
topology change FALSE
topology change time 35
topology change detected FALSE
topology change count 0
topology change last recvd. from 00-00-00-00-00-00
Other port-specific info
dynamic max age transitions 0
port bpdu ok count 0
msg age expiry count 0
link loading 1
bpdu in processing FALSE
num of similar bpdus to process 1
received_inferior_bpdu FALSE
next state 3
src mac count: 0
total src mac count 0
curr_src_mac 00-00-00-00-00-00
next_src_mac 00-00-00-00-00-00
channel_src_mac 00-00-00-00-00-00
channel src count 0
channel ok count 0
ac-sw-1> (enable)
the statistics look really strange.
Why
when
state forwarding ?
I looks like
a) bpdu-filter enabled (but I don't think so)
or
b) too many STP instances on your switch. I've got a feeling you are having a huge number of VLANs on your switch which might exceed the maximun number os STP instances (it's 4096 on Cat4000 is I remember correctly).
Milan
The only vlans running are the ones that show up in the config. I think
we have approximately 30 and not all of them are on the core net.
Kim
