Default Gateway problem in Catalyst 6509
lplanas
Hi all,
I have a problem with a Catalyst 6509. It has the CatOS 6.3.5 and two default-gateways configured. I have tried to configure one of them as primary but it does not appear in the config.
Furthermore the following messages appear repeatedly although neither one default-gateway nor the other have had problems...
2004 Oct 25 10:48:25 %SYS-5-RTE_DEFGATEFROM:Default Gateway switching from 10.16.0.1
2004 Oct 25 10:48:25 %SYS-5-RTE_DEFGATETO:Default Gateway switching to 10.16.0.11
Has anyone found something similar? Maybe a bug if the CatOS?
Thanks and regards,
LLUIS
Prashanth Krishnappa
There was a bug for this in CAT OS(first found in 5k but affects all CAT OS)
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCdt73765
But it should be fixed in the code you are running. I suggest that you open a TAC service request so that the engineer can contact development engineers on this.
