01-24-2006 09:03 PM - edited 03-03-2019 01:34 AM
Need someone to tell me if there is another way other than defining a loopback port to have an interface and its assigned ip to be the source ip of origin when performing operations from this router against other routers, switches, (ping, traceroute, tftp, etc)
Solved! Go to Solution.
01-24-2006 09:15 PM
Ping
ping
OR
Use the extended ping command i.e type in ping and hit enter. Enter in 'y' for extended commands and you will be asked for a source address
E.g router#ping
Protocol [ip]:
Target IP address: 1.1.1.1
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 16.1.1.2
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is
Packet sent with a source address of 16.1.1.2
Success rate is 0 percent (0/5)
router#
Traceroute
Do an extended traceroute
router#trace
Protocol [ip]:
Source address: 16.1.1.2
TFTP
Enter in the command 'ip tftp source-interface
FTP
Enter in the command 'ip ftp source-interface
NTP
Enter in the command 'ntp source
Hope that helps - pls rate the post if it does.
Paresh.
01-24-2006 09:15 PM
Ping
ping
OR
E.g router#ping
Protocol [ip]:
Repeat count [5]:
router#
Traceroute
router#trace
Protocol [ip]:
TFTP
FTP
NTP
Paresh.
01-24-2006 09:28 PM
thanks for the hugely informative post! the last 3 suggestions for tftp, ftp, & ntp were exactly what I was looking for.
