devices on different VLANS communicating WITHOUT ANY ROUTING???
banajahm
hi,
i have 2 switches; a nortel passport 8610 (all ports are on VLAN 1) and a catalyst 3550 (all ports are on VLAN 4). both swithces are connected via cross cable and each switch has a PC connected to it and the two PCs can ping each other (both have IP addresses of the same range).
how can the two computers talk to each other even though they are on sepirate VLANS ????
18 Replies 18
Mohammed
I believe that your understanding is correct.
Rick
Rick
thanks a lot guys. this thread was really helpful and i learned a lot. great discussion
thanks again.
Mohammed
Mohammed,
If the discussion was useful, please could you check "Rate this post" and/or "Resolved problem" for the contributions that were particularly helpful. It's a recognition for those who contributed, and helps to point other readers to helpful discussions.
Thanks in advance.
Kevin Dorrell
Luxembourg
rsharifi
Ben,
Remember that VLANs are localy significant.
So, you can have 2 switches each with different VLAN names. Switch 1 VLAN could be named "yellow" and switch 2 VLAN could be named "red" as long as they are on the same sybnet, they will talk to each other.
Reza
