Dial in router configuration problem or routing problem?
caiyan
I have a 1721(with a wic-1am card) as my dial in access server. I can dial in successfully using Windows 2000 and ping the Ethernet interface IP of 1721.But I cannot ping the IP of another router A which connected to the access server 1721 through Ethernet, and also cannot ping the IP of the third router B which connected to A through DDN leased line. I used ospf as the routing protocal in these three routers, all routers can access each other normally. So what's the problem with my network? Thanks in advance.
7 Replies 7
makchitale
Level 6
Level 6
Do you have the "redistribute connected subnets" command configured?
router ospf x
Thanks, Mak
Thank you,Mak
Ok, I have added the command" redistribute connected subnets", now I can ping router A successfully but B remains unreachable. Should I add this command to all routers?
Thanks for your help.
No we do not need to configure RouterA & RouterB with the “redistribute connected subnets”; if your routing is setup correctly the dialup client & Router B should be able to communicate.
Is the routerB configured as stub or NSSA or filtering? The running configs will be helpful.
Thanks, Mak
Ok,
Running conifiguration of Router B:
RouterB#sh run
Building configuration...
Current configuration : 5963 bytes
version 12.2
hostname RouterB
enable secret 5 $1$3gBr$w.8Ogyn7i7M.Sbc704z4//
ip subnet-zero
ip cef
no ip domain lookup
interface Loopback0
ip address 199.0.100.1 255.255.255.255
interface FastEthernet0/0
ip address 199.0.145.252 255.255.255.0
duplex auto
speed auto
standby 2 ip 199.0.145.254
standby 2 preempt
interface Serial0/0
description DDN connected to RouterA
ip address 199.0.101.17 255.255.255.252
no fair-queue
router ospf 10
log-adjacency-changes
network 199.0.101.16 0.0.0.3 area 0
network 199.0.145.0 0.0.0.255 area 0
ip classless
ip http server
line con 0
line aux 0
modem InOut
modem autoconfigure discovery
speed 300
line vty 0 4
password cisco
login
end
Running Configuration of Router A
RouterA#sh run
Current configuration : 3231 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname RouterA
enable secret 5 $1$KdJw$SSvbuxhO8jlww0hK1A6qe1
ip subnet-zero
interface Loopback0
interface Ethernet0
no ip address
shutdown
half-duplex
ip address 199.0.3.252 255.255.255.0
speed auto
standby 1 ip 199.0.3.254
standby 1 preempt
interface Serial0
Description DDN connected to RouterB
ip address 199.0.101.18 255.255.255.252
no fair-queue
router ospf 10
network 199.0.3.0 0.0.0.255 area 0
ip classless
line con 0
line aux 0
line vty 0 4
password cisco
login
end
running configuration of dialin router 1721
Cisco1721#sh run
Current configuration : 1091 bytes
version 12.2
hostname cisco1721
enable secret 5 $1$NJuF$5jEUbnKSRn1/bTtYpPbRX/
enable password cisco
username Manager password 0 cisco
ip subnet-zero
ip address 199.0.3.253 255.255.255.0
speed auto
half-duplex
no cdp enable
standby 1 priority 50
standby 1 preempt
interface Async1
ip unnumbered FastEthernet0
encapsulation ppp
dialer in-band
dialer idle-timeout 300
dialer-group 1
async default routing
async mode dedicated
peer default ip address pool default
ppp authentication chap pap ms-chap
router ospf 10
ip local pool default 199.0.3.100 199.0.3.110
ip classless
no ip http server
dialer-list 1 protocol ip permit
no cdp run
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
password cisco
login
end
1- Can the client ping 199.0.101.18 (serial ip on the RtrA)
2- sh ip ospf neigh (from all the routers)
3- sh ip route (from all the routers)
4- sh ip ospf da ex (from all the routers)
5- If the forwarding address in the output of "sh ip ospf da ex" is non-zero then send "sh ip route " from all the routers.
Thanks, Mak
