Difference Between Gain of Different Frequencies with Integrated Omnidirectional Antennas
UncleJP
Here is a quote from some ENCOR material:
Integrated omnidirectional antennas typically have a gain of 2 dBi in the 2.4 GHz
band and 5 dBi in the 5 GHz band.
Why is it that the lower frequency has less gain than the higher frequency?
Any input is appreciated.
Joseph W. Doherty
Might have to due with signal absorption and/or signal reflection from other items in the environment.
I do not think so. This is just the baseline gain from the antenna radiation.
Well that's possible too assuming the antenna is more suitable for 5 GHz vs. for 2.4 GHz (recall any antenna is only really optimal for one wavelength/frequency [https://en.wikipedia.org/wiki/Standing_wave_ratio]).
Leo Laohoo
When the power gain are set equally, 2.4 Ghz can push further than 5.0 Ghz.
NOTE: I am talking about when the setup is in a wide open field and the nearest WiFi interference is 100 metres away.
The probably reason why the antennas power gain is/was designed like that is to ensure that at a certain distance, the RSSI of the 2.4 Ghz and 5.0 Ghz are equal.
