Difference between IOS feature sets
rhollen
Is there a document that explains the difference between the feature sets available for IOS software? I would like to know if I'm choosing the right one. Up to this point, I've downloaded new IOS based upon the feature set already on the router. But would IP PLUS be better for my branch offices than just IP? Or do I even need ENTERPRISE/FW/IDS PLUS IPSEC 56 on my core router? I'm sure it has something to do with providing the proper command set to configure the router how you want to, but I have been able to determine what those differences are to make an informed decision to change the feature set currently running.
mhussein
Level 4
Level 4
You can use either of these tools:
1. Software Advisor:
on http://www.cisco.com, click on "Technical Support", then "Tools & Resources", find "Software Advisor".
Direct link http://tools.cisco.com/Support/Fusion/FusionHome.do
2. Cisco Feature Navigator:
http://www.cisco.com/go/fn
Both will you give you an option to compare IOS images and features.
HTH,
Mustafa
