Difference between protect/restrict port security violation action?
m.lammerse
Hi all,
I've read the documentation, but found the explanations a bit vague. Could someone please explain the difference between these two?
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/12_1e/comref/s1.htm#wp1184020
Thanks.
thisisshanky
Level 11
Level 11
Only difference is that, security violation counters are incremented in restrict, while its not incremented in protect.
So each time a violation occurs and you do a show port-security on that port.
Switch# show port-security interface fastethernet0/1
Port Security: Enabled
Port status: SecureUp
Violation mode: Shutdown
Maximum MAC Addresses :50
Total MAC Addresses: 11
Configured MAC Addresses: 0
Sticky MAC Addresses :11
Aging time: 20 mins
Aging type: Inactivity
SecureStatic address aging: Enabled
Security Violation count: 0
The counter above in bold will be incremented when restrict is configured, and will not increment, if protect is configured.
Either ways, the packets from the insecure hosts will be dropped, if a violation occurs.
Sankar.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
6 Replies 6
thisisshanky
Level 11
Level 11
Aging time: 20 mins
Sankar.
Sankar Nair
Clear!
Thanks Sankar..
Sankar... if I may, do you know what the point is of increasing the security violation count? IMHO , this is only a cosmetic difference. Is that correct?
Marcel
I think, its only used for statistics.
Sankar Nair
It also determines whether you can get a syslog message and SNMP trap for the event.
http://www.cisco.com/en/US/products/hw/switches/ps646/products_command_reference_chapter09186a008021145b.html#wp3062358
Kevin Dorrell
Luxembourg
OK.
I'll just stop thinking about it and store it in memory ;-)
Thanks for your replies, both.
Marcel
