Displaying TCAM info on 6500
lamprey
I'm running into TCAM table problems on our Hybrid 6509 [6.4(3)/12.1(19)E1]. The error message is "%ACL-3-TCAMFULL:Acl engine TCAM table is full". I have researched it some, and I know what the problem is (we need to trim our ACLs), but I've seen multiple references to using "show tcam count" to check on used/available TCAM resources, and this command doesn't work on our box. I can't "sh tcam" anything, in the MSFC2 or the Sup2.
I'd like to know the command to do this, so we can forecast events like this instead of blindly running into them.
t.baranski
Level 4
Level 4
"show fm xxx" (MSFC) and "show security acl resource-usage" (SUP) are the only commands I can recall for TCAM-related information on hybrid systems.
