06-24-2014 10:01 AM - edited 03-03-2019 07:28 AM
hello, dlsw protocol router does not work in 1941. enable the temporary license and a% TCP-2-INVALIDTCPENCAPS error occurs. the peer "not connet" and is "DISCONN"
**license boot module c1900 technology-package datak9**
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.4(1)T1, REL
EASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 12-Feb-14 04:27 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
ATM9296_PRUEBA uptime is 3 hours, 4 minutes
System returned to ROM by reload at 13:51:38 UTC Tue Jun 24 2014
System image file is "flash0:c1900-universalk9-mz.SPA.154-1.T1.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1941/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FTX181881BJ
6 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO1941/K9 FTX181881BJ
Technology Package License Information for Module:'c1900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
data datak9 Permanent datak9
NtwkEss None None None
*Jun 24 16:24:59.259: %TCP-2-INVALIDTCPENCAPS: Invalid TCB encaps pointer: 0x2B6
682A4 -Process= "DLSw Background", ipl= 0, pid= 257
-Traceback= 23457A4Cz 2214700Cz 22102014z 261B40F8z 261B4188z 22100B58z 220F9880
z 22111978z 241156A8z 2411568Cz
ATM9296_PRUEBA# sh dl pe
Peers: state pkts_rx pkts_tx type drops ckts TCP uptime
TCP 167.28.62.9 PCONN_WT 2 2 conf 0 0 - -
TCP 167.28.61.214 DISCONN 0 0 conf 0 0 - -
Total number of connected peers: 0
Total number of connections: 0
ATM9296_PRUEBA#
*Jun 24 16:53:36.183: DLSw: START-TPFSM (peer 167.28.62.9(2065)): event:ADMIN-OP
EN CONNECTION state:DISCONN
*Jun 24 16:53:36.183: DLSw: dtp_action_a() attempting to connect peer 167.28.62.
9(2065)
*Jun 24 16:53:36.183: DLSw: END-TPFSM (peer 167.28.62.9(2065)): state:DISCONN->W
AIT_WR
*Jun 24 16:53:36.183: DLSw: Async Open Callback 167.28.62.9(2065) -> 13087
*Jun 24 16:53:36.183: DLSw: START-TPFSM (peer 167.28.62.9(2065)): event:TCP-WR P
IPE OPENED state:WAIT_WR
*Jun 24 16:53:36.183: DLSw: dtp_action_f() start read open timer for peer 167.28
.62.9(2065)
*Jun 24 16:53:36.183: DLSw: END-TPFSM (peer 167.28.62.9(2065)): state:WAIT_WR->W
AIT_RD
*Jun 24 16:53:36.187: DLSW: dlsw_access_check(): sport=1074 dport=2065 vrf_table
id=0x0 vrf_string =
*Jun 24 16:53:36.187: DLSw: passive open 167.28.62.9(1074) -> 2065
*Jun 24 16:53:36.187: DLSw: START-TPFSM (peer 167.28.62.9(2065)): event:TCP-RD P
IPE OPENED state:WAIT_RD
*Jun 24 16:53:36.187: DLSw: dtp_action_g() read pipe opened for peer 167.28.62.9
(2065)
*Jun 24 16:53:36.187: DLSw: CapExId Msg sent to peer 167.28.62.9(2065)
*Jun 24 16:53:36.187: DLSw: END-TPFSM (peer 167.28.62.9(2065)): state:WAIT_RD->W
AIT_CAP
*Jun 24 16:53:36.187: DLSw: START-TPFSM (peer 167.28.62.9(2065)): event:SSP-CAP
MSG RCVD state:WAIT_CAP
*Jun 24 16:53:36.187: DLSw: dtp_action_j() cap msg rcvd from peer 167.28.62.9(20
65)
*Jun 24 16:53:36.187: DLSw: Recv CapExId Msg from peer 167.28.62.9(2065)
*Jun 24 16:53:36.187: DLSw: Pos CapExResp sent to peer 167.28.62.9(2065)
*Jun 24 16:53:36.187: DLSw: END-TPFSM (peer 167.28.62.9(2065)): state:WAIT_CAP->
WAIT_CAP
65)
*Jun 24 16:53:36.187: DLSw: Recv CapExPosRsp Msg from peer 167.28.62.9(2065)
WAIT_CAP
*Jun 24 16:53:36.191: DLSw: Processing delayed event:SSP-CAP EXCHANGED - prev st
ate:WAIT_CAP
*Jun 24 16:53:36.191: DLSw: START-TPFSM (peer 167.28.62.9(2065)): event:SSP-CAP
EXCHANGED state:WAIT_CAP
*Jun 24 16:53:36.191: DLSw: dtp_action_k() cap xchged for peer 167.28.62.9(2065)
*Jun 24 16:53:36.191: DLSw: END-TPFSM (peer 167.28.62.9(2065)): state:WAIT_CAP->
PCONN_WT
no deb all
All possible debugging has been turned off
ATM9296_PRUEBA#
ATM9296_PRUEBA#
*Jun 24 16:53:51.207: %TCP-2-INVALIDTCPENCAPS: Invalid TCB encaps pointer: 0x2B6
-Traceback= 23457A84z 22147024z 22102014z 261B40F8z 261B4188z 22100B58z 220F9880
-Traceback= 23457C84z 22103C68z 22103D74z 220F035Cz 2210201Cz 261B40F8z 261B4188
z 22100B58z 220F9880z 22111978z 241156A8z 2411568Cz
-Traceback= 23457CE4z 22103C7Cz 22103D74z 220F035Cz 2210201Cz 261B40F8z 261B4188
06-25-2014 01:01 AM
There was a caveat for the old IOS versions. You can make use of the work around option to solve. But am not sure if the same exist for your IOS version.
You may receive the following information every day after upgrading Cisco IOS Release 11.3 to Release 12.0(13):
0x0
-Process= "IP Input", ipl= 0, pid= 12
-Traceback= 60382C2C 60383F14 60A56FF0 60A583F8 60A569E4 60A46840 60A4E58C
60382B78 602EAE00 602ECB84 603233D4 6030BD04 6030A200 6030A2FC 6030A470 6
02973AC
This situation is specific to a data-link switching (DLSw) border peer network. It does not happen in a standard DLSw environment with only configured or promiscuous DLSw peers. There is no workaround.
Karthik
