07-14-2004 01:22 AM - edited 03-02-2019 05:03 PM
hi,
after making an erase flash on my 1721 router, the router prompted me rommon>
i want to install a new Ios
how to do it??
thanks.
07-14-2004 01:37 AM
in ROMMON mode, you have to use either TFTP or XMODEM to download a new image to flash.
Check this document and scroll down to the section 'Downlaod Using TFTP from ROMMON':
CISCO 1700 SERIES MODULAR ACCESS ROUTERS
ROMmon Recovery for the Cisco 1700 Series Router
HTH,
GP
07-14-2004 06:26 AM
Try the following link for tftp dnld or use xmodem but make sure to increase the console speed if using xmodem protocol
Sonu
