09-25-2004 09:43 PM - edited 03-02-2019 06:46 PM
I have an F5 Load Balancer connect to a 3750 via an ether channel that contains two gig ports. It works great, but when I copy the port configurations to my 6513 I get input errors.
The 3750 is running Version 12.1(14)EA1a and the 6513 is running 12.2(17d)SXB1.
Here is the configuration.
interface Port-channel1
no ip address
speed nonegotiate
switchport
switchport access vlan 137
switchport mode access
switchport nonegotiate
spanning-tree portfast
end
interface GigabitEthernet5/23
no ip address
load-interval 30
speed nonegotiate
switchport
no cdp enable
channel-group 1 mode on
end
09-26-2004 12:29 AM
Are you sure that you don't have connectivity problems? When you see input errors it could be an error with the cable or the GBic. Had you tried another cable and/or port?
You configure a manually etherchannel. Had you tried a LACP Etherchannel on the catalyst? (channel-group 1 mode active)
Peter
09-27-2004 11:46 AM
The channels do not come up with the active mode statement.
F5's Big IP do not support LACP.
I am still getting the errors on the 6513, but I do not get any on the 3750 switch.
These devices are directly connected to the 6513 via fiber. The connections run over multiple blades and all the ports are getting the errors.
I do not think it is a physical connection issue.
09-27-2004 11:23 PM
which module you use on the cat 6509? Had you tried another module?
Peter
09-30-2004 06:15 AM
The modules are WS-X6724-SFP. All bundles have half its ports on one card and the other half on the other card.
We disabled the port channel yesterday and used a single port for connectivity. We did not get any errors. Once we put the port back into the port channel and reenabled it the errors came back.
We have captured the 6513 putting arp request that are only 60 bytes. Does the 6513 record these as errors?
Jim
10-04-2004 03:38 AM
Hi Jim,
sorry for my late response. I would made a test in our lab. But unfortunally i had many things to do.
I found a bug which describe the similar behaviour you see:
CSCec07464
On the catalyst 4000 family IOS switches, input errors may incrment for an interface. This does not always indicate any loss of data traffic.
Sometimes, symbol errors and sequence errors increment for an interface but do not result in corruption of data packets. Hence the problem seems to be cosmetic.There is no workaround for this problem.
The problem has been resolved in 12.1(20)EW, 12.1(20)E and later releases. In these releases, symbol errors and sequence errors that do not affect data packets are not counted as input errors. Symbol errors for an interface are counted and can be seen
with "show interface
This problem is related to your software also (12.2(17d)SXB1). Perhaps you should try anther software.
When this don't solved your problems, i would open a tac case.
Peter
