Ethernet Frame Header - Trailer (Variable Length)
kfarrington
Level 3
Level 3
All,
I have four frames below (captured using ethereal) and would like to know what the trailer in the L2 frame is?
Is it just to pad the packet to the minimum ethernet frame length?
Many kind regards in advance,
Ken
Trailer 6 bytes
Frame 102 (60 bytes on wire, 60 bytes captured)
Arrival Time: Jul 16, 2003 06:36:44.412671000
Time delta from previous packet: 0.139895000 seconds
Time since reference or first frame: 2.674510000 seconds
Frame Number: 102
Packet Length: 60 bytes
Capture Length: 60 bytes
Ethernet II, Src: 00:02:a5:34:03:86, Dst: 00:50:8b:fd:d7:54
Destination: 00:50:8b:fd:d7:54 (CompaqCo_fd:d7:54)
Source: 00:02:a5:34:03:86 (30.42.101.39)
Type: IP (0x0800)
Trailer: 000000000000
Internet Protocol,
Trailer (lots of bytes)
Frame 113 (60 bytes on wire, 60 bytes captured)
Arrival Time: Jul 16, 2003 06:36:44.689337000
Time delta from previous packet: 0.071447000 seconds
Time since reference or first frame: 2.951176000 seconds
Frame Number: 113
Ethernet II, Src: 00:02:a5:34:b2:33, Dst: ff:ff:ff:ff:ff:ff
Destination: ff:ff:ff:ff:ff:ff (Broadcast)
Source: 00:02:a5:34:b2:33 (30.42.101.43)
Type: ARP (0x0806)
Trailer: 00000000000000000000000000000000...
Address Resolution Protocol (request)
Trailer 3 bytes
Frame 139 (60 bytes on wire, 60 bytes captured)
Arrival Time: Jul 16, 2003 06:36:45.230010000
Time delta from previous packet: 0.007420000 seconds
Time since reference or first frame: 3.491849000 seconds
Frame Number: 139
Ethernet II, Src: 00:b0:c2:d1:b7:fc, Dst: 00:50:8b:fd:d7:54
Source: 00:b0:c2:d1:b7:fc (Cisco_d1:b7:fc)
Type: IP (0x0800)
Trailer: 000000
Trailer 5 bytes
Frame 175 (60 bytes on wire, 60 bytes captured)
Arrival Time: Jul 16, 2003 06:36:46.134412000
Time delta from previous packet: 0.000769000 seconds
Time since reference or first frame: 4.396251000 seconds
Frame Number: 175
Type: IP (0x0800)
Trailer: 0000000000
Internet Protocol,
wdrootz
Level 4
Level 4
Trailer is like a label negotiated between the routers for specific packet along with CRC and the Trailer will be different according to the packet size.
Thats great. Many thx for the info. I am just wondering is this protocol field and contents is documented anywhere?
Do you have any idea about this?
Many kind regards,
Ken
