Fiber Light Meter
mansoor_nawaz78
We have almost 50 2950 and 3550 Switch, which are interconnected with fiber modules. How can i monitor Fiber cable losses, in a real time.
Waiting for a reply,
Thank You.
Why not use a monitoring software to monitor all your fiber links? I think that way you would be able to know almost everything you would want to know about your links!
I wouls suggest Solawinds for the same.
More here --> http://www.solarwinds.net/Toolsets.htm
Hope this helps.
Please rate all posts.
AbhisheK
Thank you for the reply,
But can u please tell me any specific tool, which i use to find it.
Thank You again.
I already mentioned "Solarwinds". Its a great tool.
You can find more about it here --> http://www.solarwinds.net
It'll give you all the details about your links which you may want including the packets dropped and the availability of a particular device/link etc.
Hope this helps.
AbhisheK
