Flexible netflow not generating flows
girish_gavandi
Dear All,
I have configured a cisco 2951 router for cisco flexible netflow v9. Router running IOS image version
c2951-universalk9-mz.SPA.151-4.M4.bin. But it is not generating any flows nor populating the cache.
Network node manager is configured to collect the flows from the 2951 router.
Any ideas why it is not generating the flows? Your suggestions are highly appreciated.
Below are the commads applied to the router and also the show output of the cache,
flow record MOIFR
desc NBAR Flexible Netflow Record
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
match interface output
match flow direction
match ipv4 source mask
match ipv4 destination mask
collect  transport tcp flags
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter MOIFE
description Flexible NetFlow Exporter
destination 10.10.10.1
source loopback0
transport udp 9996
template data timeout 600
option interface-table
option exporter-stats
option sampler-table
flow monitor MOIFM
record MOIFR
exporter MOIFE
cache timeout active 60
int gig 0/1
ip flow monitor MOIFM input
ip flow monitor MOIFM output
R02#sh flow monitor MOIFM cache format table
  Cache type:                               Normal
  Cache size:                                 4096
  Current entries:                               0
  High Watermark:                                0
  Flows added:                                   0
  Flows aged:                                    0
    - Active timeout      (    60 secs)          0
    - Inactive timeout    (    15 secs)          0
    - Event aged                                 0
    - Watermark aged                             0
    - Emergency aged                             0
There are no cache entries to display.
R02#sh flow monitor MOIFM cache format record
  Cache type:                               Normal
  Cache size:                                 4096
  Current entries:                               0
  High Watermark:                                0
  Flows added:                                   0
  Flows aged:                                    0
    - Event aged                                 0
    - Watermark aged                             0
    - Emergency aged                             0
Girish
jakewilson
Hello Girish,
When you state "it is not generating any flows nor populating the cache" does this mean that wireshark didn't see any flows? I would verify this by putting a packet analyzer as close as possible to the interface that the datagrams should be leaving on.
I noticed that your record description includes 'NBAR'.  If you want to export NBAR, you need to include the following in the record definition:
match application name
When you define the flow exporter, I would change 600 to 60 and you need to include the NBAR application-table option template:
option application-table timeout 60
I hope this helps. Here's a good post on NetFlow v9 NBAR.
Jake
Hi Jake,
Tested your suggestions, no luck!
The router itself is not generating any packets. Debug command doest give any output. The network node manager was configured to receive these netflow packets. The people managing this NNM also tried capturing the packets but nothing.
This happens not only with this particular router but there many others with different hardware configurations and IOS versions. Same comamnds have been put on them as well.
Any ideas would be appreciated.
Girish
Perhaps try traditional NetFlow 5 configuration without flexible netflow.  See if that works.
