forwarding switch info to a pc
chillewillie
hi guys,
For my uni project i'm going to create a simple web based program that monitors your switches within your network.
of course it's been done but uni projects don't have to be new :P
the problem is how do i gather that information? how can i make the switch forward information like
-connected pc's ip and mac addresses
-traffic utilisation for each port etc?
-switch configuration etc
how can i make the switch send me the data that i need?
thanks guys
Will
Justin Reeve
Do an SNMPGET for the information that you need e.g
snmpwalk -c public@2 10.1.1.179 1.3.6.1.2.1.17.4.3.1.1
will give you an snmpwalk of the BRIDGE-MIB on the device, the device will return the MAC addresses where public is the RO community and 2 is the VLAN that your interested in.
Cheers
J
hi,
is there another way?
can't u have the router send this information?
perhaps i should be more specific.
i want to be able to show in the web based gui that i create what computers are connected to each switch.
So for example i have switch "one" and this switch will have computers 1 2 and 3..with mac adresses AED....and ip's of 192.1.....etc.
problem is how do i get that data? so i can represent it in the GUI
thanks in advance.
will
You'll have to do as the previous poster suggested--go get the information you desire.
Cisco switches and routers aren't able to do periodic data dumps as you're looking for. Their sole purpose is to switch and/or route traffic.
You can have switches send an snmp trap when a workstation connects/disconnects, then based on that have the server get (via snmp) the information.
