03-12-2002 10:35 AM - edited 03-01-2019 08:50 PM
Hy
I heard that it should possible with IOS version 12.1
In a frame-Relay Enviroment Hub and Spoke.
1 Hub and three Spokes. Running Routing Protocol OSPF.
It should be possible, when I do area0 authentication, that I have the possibility to do this only on one Spoke, altough all spokes are in Area 0.
That means I do some autentication per link.
I tryed to find something on the CCO but without success.
When anybody already know or heard about it, it would be glad to give some Info or link where I could check this.
Thanks in advance
03-13-2002 12:29 AM
HI,
Yake a look at the following link, I think it's got the information you need. Otherwise drop me another message and I'll try to help you with your config.
http://www.cisco.com/warp/customer/104/25.shtml
Ciao :-)
03-13-2002 02:23 AM
Hi.
I'm afraid it isn't possible to do. What you can do is having different passwords per interface. In your case, Hub & Spoke, if you are using a single Frame-Relay main interface or Point-to-Multipoint subinterface you have to use the same password.
Nuno Morais
