Frame relay backup using dsl instead of isdn
majznerr
I'm wondering if this is feasable. Isdn doesn't seem
to have the bandwidth that we need. We do have plenty of bandwidth at our hub, and are backing up 256 to 768k sites. Any help would be appreciated.
Ron
vcjones
Level 5
Level 5
It is very feasible, but there are security implications if the DSL network is an Internet connection. Think IPsec VPNs in that case.
Think through what you are doing, because unless it is a private DSL network, it is very easy to inadvertently open up holes in your defenses that you don't want. There can also be performance issues with IPsec despite the added bandwidth. Some applications are inordinately sensitive to delay while others will have trouble with MTU reduction when connected.
Good luck and have fun!
Vincent C Jones
www.networkingunlimited.com
Thanks. Is there a place you can point me that will
address some of the security issues, and work arounds.
Ron
Everything you need to know, and would want to about configuring DMVPN is in this PDF file.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t13/ftgreips.pdf
