04-28-2003 08:02 AM - edited 03-02-2019 06:57 AM
I have two 2500 and one 3600 connected together via Frame Relay. I configured the 3600 to be a FR switch and is providing clocking on each interface to each of the 2500's. The 2500 are the DTE's. The interfaces are X.21 and they are connected back to back with the 3600 using a DCE cable. The interfaces show they are up, the LMI is up at both ends but I cant ping from one 2500 to the other, or to the LAN interface on each of the 2500's. Sh cdp neigh does not show any of the routers, and the ip route command only shows the subnets directly attached to each router.
Does anyone have any idea what I am doing wrong?
Many thanks.
Arturo Maldonado
05-14-2003 06:00 AM
Dennis,
I manage to fix my original problem. The problem was that I had misconfigured the clock rate in both interfaces of the switch. the setting is in bits per second and I assumed that it was in Kbps so I had configured a 1000 bps interface and a 500 bps interface. Instead of the 1Mbps and 500 kbps that I wanted.
Anyway now I have a different problem and I am writing to you becuase you seem to have experimented with Cisco routers as switches. The DCE as I said is a 3600 router, which I labeled as Router 3, and I want to connect it to another router (Router 4) via a Fastethernet in a different subnet to where Routers 1 and 2 are (the FR DTEs). So the question is, how can I do to advertise the subnets configured in Router 4 so Routers 1 and 2 know about them, and viceversa.
EIGRP is configured in four routers and they are all in the same AS.
Many Thanks for your help.
Arturo.
05-09-2003 08:27 AM
Arturo,
I have been watching your problem, now i have a problem with frame-relay look like your.
Can you send me a e-mail ?, maybe i can help you.
Best Regards
Luis
05-09-2003 08:30 AM
you should also be able to do a sh fram pv on the 2500 to see what dlci's the 3600 is advertising to you. you may also need to set clock on the 2500's. here is a full mesh fram config if you want it.
sj
r7# wr t
Building configuration...
Current configuration : 6406 bytes
version 12.2
no parser cache
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname r7
logging rate-limit console 10 except errors
enable password cisco
ip subnet-zero
no ip domain-lookup
ip host sw 192.168.255.9
ip host linux 192.168.255.101
ip host switch 172.16.255.2
no ip dhcp-client network-discovery
frame-relay switching
call rsvp-sync
interface Serial0/0
description r1
no ip address
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
logging event subif-link-status
logging event dlci-status-change
keepalive 20
no fair-queue
clockrate 72000
frame-relay lmi-type ansi
frame-relay intf-type dce
frame-relay route 102 interface Serial0/1 201
frame-relay route 103 interface Serial0/2 301
frame-relay route 104 interface Serial0/3 401
frame-relay route 105 interface Serial1/0 501
frame-relay route 106 interface Serial1/1 601
frame-relay route 107 interface Serial1/2 701
frame-relay route 108 interface Serial1/3 801
interface Serial0/1
description r2
no ip address
no ip route-cache
no ip mroute-cache
keepalive 20
no fair-queue
clockrate 72000
frame-relay route 201 interface Serial0/0 102
frame-relay route 203 interface Serial0/2 302
frame-relay route 204 interface Serial0/3 402
frame-relay route 205 interface Serial1/0 502
frame-relay route 206 interface Serial1/1 602
frame-relay route 207 interface Serial1/2 702
frame-relay route 208 interface Serial1/3 802
interface Serial0/2
description r3
no ip address
no ip route-cache
no ip mroute-cache
keepalive 20
no fair-queue
clockrate 2016000
frame-relay route 301 interface Serial0/0 103
frame-relay route 302 interface Serial0/1 203
frame-relay route 304 interface Serial0/3 403
frame-relay route 305 interface Serial1/0 503
frame-relay route 306 interface Serial1/1 603
frame-relay route 307 interface Serial1/2 703
frame-relay route 308 interface Serial1/3 803
interface Serial0/3
description r4
no ip address
no ip route-cache
no ip mroute-cache
keepalive 20
frame-relay route 401 interface Serial0/0 104
frame-relay route 402 interface Serial0/1 204
frame-relay route 403 interface Serial0/2 304
frame-relay route 405 interface Serial1/0 504
frame-relay route 406 interface Serial1/1 604
frame-relay route 407 interface Serial1/2 704
frame-relay route 408 interface Serial1/3 804
interface Serial1/0
description r5
no ip address
no ip route-cache
no ip mroute-cache
keepalive 20
no fair-queue
clockrate 72000
frame-relay route 501 interface Serial0/0 105
frame-relay route 502 interface Serial0/1 205
frame-relay route 503 interface Serial0/2 305
frame-relay route 504 interface Serial0/3 405
frame-relay route 506 interface Serial1/1 605
frame-relay route 507 interface Serial1/2 705
frame-relay route 508 interface Serial1/3 805
interface Serial1/1
description r6
no ip address
no ip route-cache
no ip mroute-cache
keepalive 20
no fair-queue
clockrate 72000
frame-relay route 601 interface Serial0/0 106
frame-relay route 602 interface Serial0/1 206
frame-relay route 603 interface Serial0/2 306
frame-relay route 604 interface Serial0/3 406
frame-relay route 605 interface Serial1/0 506
frame-relay route 607 interface Serial1/2 706
frame-relay route 608 interface Serial1/3 806
interface Serial1/2
description r7
ip address 30.30.30.1 255.255.255.252
no ip route-cache
no ip mroute-cache
keepalive 20
no fair-queue
clockrate 72000
interface Serial1/3
description r8
no ip address
no ip route-cache
no ip mroute-cache
keepalive 20
no fair-queue
clockrate 72000
frame-relay route 801 interface Serial0/0 108
frame-relay route 802 interface Serial0/1 208
frame-relay route 803 interface Serial0/2 308
frame-relay route 804 interface Serial0/3 408
frame-relay route 805 interface Serial1/0 508
frame-relay route 806 interface Serial1/1 608
frame-relay route 807 interface Serial1/2 708
interface FastEthernet2/0
ip address 192.168.255.1 255.255.255.0
duplex auto
speed auto
interface Serial2/0
ip address 160.160.1.2 255.255.255.252
clockrate 148000
interface FastEthernet2/1
ip address 10.5.0.1 255.255.255.0
duplex auto
speed auto
interface Serial2/1
ip address 63.63.1.1 255.255.255.252
interface FastEthernet3/0
ip address 10.70.0.2 255.255.255.0
duplex auto
speed auto
router eigrp 1
redistribute static route-map default
network 10.0.0.0
no auto-summary
no eigrp log-neighbor-changes
router bgp 3
bgp log-neighbor-changes
neighbor 30.30.30.2 remote-as 5
neighbor 63.63.1.2 remote-as 4
neighbor 160.160.1.1 remote-as 2
ip classless
ip route 0.0.0.0 0.0.0.0 10.5.0.20
ip route 0.0.0.0 0.0.0.0 10.70.0.3
no ip http server
access-list 1 permit 0.0.0.0
route-map default permit 10
match ip address 1
dial-peer cor custom
alias exec c configure terminal
alias exec si show ip route
alias exec ci clear ip route *
alias exec oi show ip ospf interface
alias exec ion show ip ospf neighbor
alias exec ib show ip bgp
alias exec cib clear ip bgp *
alias exec ibn show ip bgp neighbor
alias exec wrb sho run | begin
alias exec sib show ip interface brief
line con 0
exec-timeout 0 0
privilege level 15
password cisco
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
transport input all
line vty 0 4
exec-timeout 0 0
privilege level 15
password cisco
login
ntp clock-period 17179817
ntp server 137.20.20.1
end
r7#
05-14-2003 05:53 AM
I could not set the clock rate in the 2500's because they are the DTEs and the IOS complained that this is a feature of a DCE device. However, when trying to setup the clock rate in one of the DTEs I noticed that this setting is in bits per second, and not in kilobits per second as i initially thought. Once I corrected the clock rate value in both FR interfaces of the switch I managed to get pings from one DTE to the other across the DCE.
Many thanks to every one who helped me to sort out this problem.
Now I have a different problem. The DCE as I said is a 3600 router, which I labeld as Router 3, and I want to connect it to another router (Router 4) via a Fastethernet in a different subnet to where Routers 1 and 2 are (the FR DTEs). So the question is, how can I do to advertise the subnets configured in Router 4 so Routers 1 and 2 know abot them, and viceversa.
Many Thanks.
Arturo.
05-14-2003 06:18 AM
Check to see if the segment (fast ethernet) between R3 and R4 are enabled with EIGRP.
05-15-2003 01:25 AM
I suppose it is, as they can see each other with the command sh ip eigrp neighbour.
Router_3 is esentially a FR switch and a Router. So how can we do to advertise the networks configured in the router part of Router_3 to the switch side of the same router? Is it possible at all?
I know I can achieve that by using an additional router configured as a hub router with another FR interface to Router_3 but my problem is that it may be difficult to find the hardware required, cables router, etc. That's is why I want to find an alternative to this problem with what I've got.
Many thanks.
Arturo Maldonado.
05-15-2003 05:27 AM
The frame switch and router functions are separate. The frame switch is a telco device, not a part of your network. Any interfaces on "the frame switch" router that are not configured for switching can be used for routing so they can be build into lab scenarios but they cannot see the switch ports.
