Frame Relay problems
james.graves
I have a new Frame Relay cloud that I need to connect five remote offices to my home office. I am using Cisco 1720 routers to accomplish this task.
I have setup one remote site already using subinterface settings. The problem I am having is that I have to set an ip address on the S0 interface to make this work. When I look at Tac it shows me as leaving a "no ip address" on S0. When I do this I lose my frame connection. Below are my configs;
Home Office setup
interface Serial0
ip address 192.168.1.82 255.255.255.252 " Was set to No Ip address"
encapsulation frame-relay
interface Serial0.1 point-to-point
frame-relay interface-dlci 555
Remote Office setup
interface Serial0
ip address 192.168.1.81 255.255.255.252
frame-relay interface-dlci 560
frame-relay lmi-type cisco
Any ideas?
Jim
vmiller
Level 7
Level 7
THe TAC example may have been one for inverse arp or ip unnumbered
using a lan interface address. Either way, if there is no compelling need
to not have IP on the frame relay interfaces, just leave it....it aint broke...
vmiller
Level 7
Level 7
heres a url for an example on how to do frame with inverse arp
note the differences in how the interfaces are configured
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_configuration_example09186a008009421f.shtml
nsabnis
Dear just do one thing create a subinterface at remote site also. i mean instead of giving ip address to s0 u define ip address on s0.1 on remote site.
basically this is a hub and spoke type of thing.from one hub u want to connect no of site. so create 5 sub int on central site..like sub int0.1,0.2 ,0.3 etc and then do point to point mapping with remote site. remember with point to point u have to create subinterface.
now just do this
interface s0
no ip address
encap frame relay
interface Serial0.1
and repete this for all other site. ur prob will be solved.
Actually I had that exact setup in my configs. When I couldn't get it to work that way I changed it to the way you see now.
