FTP problems still...
jmartina
ok..I posted this last week, and i still can not get it to work, everything else works...but can't get ftp to work...does any one have a config i can compare?
here is entire config
Current configuration : 3170 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname router1
logging buffered 16384 debugging
enable secret 5
memory-size iomem 15
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
ip tcp path-mtu-discovery
ip dhcp pool dhcppool
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
lease 7
no ip bootp server
ip audit attack action alarm reset
ip audit notify log
ip audit po max-events 100
ip cef
interface Ethernet0
ip address dhcp
ip access-group 100 in
ip access-group 101 out
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting access-violations
ip nat outside
half-duplex
ntp disable
no cdp enable
interface FastEthernet0
ip address 10.10.10.1 255.255.255.0
ip nat inside
speed auto
no cdp enable
ip nat inside source list 1 interface Ethernet0 overload
ip nat inside source static tcp 10.10.10.60 13015 interface Ethernet0 13015
ip nat inside source static tcp 10.10.10.60 13014 interface Ethernet0 13014
ip nat inside source static tcp 10.10.10.60 13013 interface Ethernet0 13013
ip nat inside source static tcp 10.10.10.60 13012 interface Ethernet0 13012
ip nat inside source static tcp 10.10.10.60 13011 interface Ethernet0 13011
ip nat inside source static tcp 10.10.10.60 13010 interface Ethernet0 13010
ip nat inside source static tcp 10.10.10.60 21 interface Ethernet0 21
ip nat inside source static tcp 10.10.10.60 20 interface Ethernet0 20
ip classless
no ip http server
ip pim bidir-enable
ip access-list extended internet-in
logging 10.10.10.66
access-list 1 permit 10.0.0.0 0.255.255.255 log
access-list 100 permit tcp any any established log
access-list 100 permit tcp any gt 1023 host 10.10.10.60 eq ftp-data log
access-list 100 permit tcp any gt 1023 host 10.10.10.60 eq ftp log
access-list 100 permit tcp any gt 1023 host 10.10.10.60 eq 1023 log
access-list 100 permit icmp any any net-unreachable
access-list 100 permit icmp any any host-unreachable
access-list 100 permit icmp any any port-unreachable
access-list 100 permit icmp any any parameter-problem
access-list 100 permit icmp any any packet-too-big
access-list 100 permit icmp any any administratively-prohibited
access-list 100 permit icmp any any source-quench
access-list 100 permit icmp any any echo-reply
access-list 100 permit ip any any log
access-list 101 permit ip any any log
access-list 101 permit tcp any any log
access-list 101 permit udp any any log
no cdp run
banner motd ^C
* WARNING *
line con 0
line aux 0
line vty 0 3
password 7
login
telnet refuse-negotiations
line vty 4
password 7
login
19 Replies 19
Yes, it was me indeed. Just checking if everything was working fine. It is working now ;o)
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
u can get to it?
ok..i see on my FTP server you got through, why wont it allow me to connect from with in the network, meaning i can if i go to ftp://10.10.10.60 but not ftp://24.223.139.x , this is wierd...so its probably worked all along ,accept i have only tested from with in my own network....do you know off the top of your head why it denys me to do this ? ..thanks this really takes some stress off of me....1000 points
If the FTP session is established from a workstation on the same subnet then NAT is not involved at all. You then need to used the local address (10.10.10.60). The global address should only be used if the FTP session is established from the Internet. In other words the behavior you are seeing is normal.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
yes...i understand now....its not like using a netgear which i was able to do it that way for troubleshooting....hey thanks for all your help...
