FTP traffic configured to use Interface Loopback
Sparkeyluv_357
Why would someone configure FTP to  use interface Loop back within a routers configuration?
Example:
Why would someone configure a routers FTP to use a loop back address?
interface Loopback0
description Loopback interface
ip address x.x.x.x x.x.x.x
no ip directed-broadcast
ip telnet source-interface Loopback0
ip tftp source-interface Loopback0
ip ftp source-interface Loopback0
Giuseppe Larosa
the loopback interface is a logical interface that is always up/up if the device is alive.
The loopback interface has to be advsertised and this is the only drawback.
Using a loopback interface is so the better way to make the device to use the same Source IP address in accessing services like an FTP server and so on like for example a Radius or Tacacs+ server.
So when reviewing activity logs you can always be sure that IP 10.1.1.1 means that specific router and not another one.
Loopback interfaces are also very important in networking for example for internal BGP and MPLS and all MPLS based services.
Without setting those  source commands the router would use the interface in the path to the destination, that can change for different destinations and can change over time if the primary interface goes down.
Hope to help
Giuseppe
So from what i'm gathering in your post, Loopback interfaces are used
As they are always active (up/up)
It can use its self as the source for FTP/Tacacs+ and other services
Ease of verifying its self as the source within logs
Am I correct?
yes your understanding is correct
Hope to help
Giuseppe
"It can use its self as the source for FTP/Tacacs+ and other services"
Hopefully you understand the "other services", but for example other devices can use an ACL (or FW rules) to block, or not, traffic using the loopback IP. Also, loopbacks aren't just for traffic sourced from the device they are often used as a management IP for the device too.
