gre over ipsec routing ospf not working
i have create a gre over ipsec in 2 routers
but ospf routing is not working
i make a gre over ipsec form router 1 Tunnel2354 to router 2 Tunnel2354
this connection is good . i can ping to Tunnel ip form other router
what i try i do . is
i need router 1 access router 2  all subnets  which router 2 can access to
this is router 1 config
Building configuration...
Current configuration : 1868 bytes
version 12.3
service password-encryption
service udp-small-servers
service tcp-small-servers
hostname R1
boot-start-marker
boot-end-marker
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip ips po max-events 100
crypto isakmp policy 56
encr aes
authentication pre-share
crypto isakmp key rMVvTRvm2Hw7rUxCdIGQAOsiwfmXv1/i address # xxx.xxx.xxx.xxx #this is destination router ip
no crypto isakmp ccm
crypto ipsec transform-set device1 esp-aes esp-sha-hmac
crypto ipsec profile deviceProfile1
set transform-set device1
interface Tunnel2354
ip address 10.54.65.1 255.255.255.0
tunnel source FastEthernet0/0
tunnel destination xxx.xxx.xxx.xxx #this is destination router ip
tunnel protection ipsec profile deviceProfile1
interface Loopback2
ip address 10.54.63.1 255.255.255.0
interface FastEthernet0/0
ip address xxx.xxx.xxx.xxx 255.255.255.252 #xxx.xxx.xxx.xxx #this is router ip
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip nat inside
duplex auto
speed auto
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
network 10.54.63.0 0.0.0.255 area 0
network 10.54.65.0 0.0.0.255 area 0
network 192.168.1.0 0.0.0.255 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 #xxx.xxx.xxx.xxx #this is router ip
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
C 213.221.44.136 is directly connected, FastEthernet0/1
10.0.0.0/24 is subnetted, 2 subnets
C 10.54.63.0 is directly connected, Loopback2
C 10.54.65.0 is directly connected, Tunnel2354
C 192.168.1.0/24 is directly connected, FastEthernet0/1
S* 0.0.0.0/0 [1/0] via xxx.xxx.xxx.xxx
this is router 2 config
Current configuration : 5941 bytes
version 12.4
no service pad
hostname R2
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local
aaa session-id common
encr aes
crypto isakmp key rMVvTRvm2Hw7rUxCdIGQAOsiwfmXv1/i address xxx.xxx.xxx.xxx #this is destination router ip
archive
log config
hidekeys
interface Loopback2
ip address 10.54.64.1 255.255.255.0
interface Tunnel1111
ip address 10.226.1.140 255.255.255.192
no ip redirects
ip mtu 1400
ip hold-time eigrp 1 35
ip nhrp map 10.226.1.129 xxx.xxx.xxx.xxx
ip nhrp map multicast xxx.xxx.xxx.xxx
ip nhrp network-id 1
ip nhrp nhs 10.226.1.129
ip tcp adjust-mss 1360
no ip split-horizon eigrp 1
tunnel source Dialer1
tunnel mode gre multipoint
tunnel key 1
ip address 10.54.65.2 255.255.255.0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
ip address 10.14.0.1 255.255.252.0
ip nat inside
ip tcp adjust-mss 1452
interface Dialer1
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
no cdp enable
router eigrp 1
network 10.14.0.0 0.0.3.255
network 10.226.1.128 0.0.0.63
auto-summary
router ospf 1
router-id 2.2.2.2
network 10.14.0.0 0.0.255.255 area 0
network 10.54.64.0 0.0.0.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip http authentication local
ip nat inside source list Inet interface Dialer1 overload
ip access-list extended DEFENCE
permit udp any host 89.109.36.88 eq isakmp non500-isakmp
permit esp any host 89.109.36.88
permit icmp any host 89.109.36.88
permit tcp any host 89.109.36.88 eq 4444
permit gre any host 89.109.36.88
deny ip any any
ip access-list extended Inet
permit ip 10.14.0.0 0.0.3.255 any
no cdp run
5 Replies 5
first are you sure the Tunnel is UP ?
second there are two tunnel share same Dialer interface ?
this is my tunnel in tow routers  and it is up
this is my tunnel >> Tunnel2354
from router 1
i can ping 10.54.65.2
and ping 10.54.65.1
and from router 2
and ping 10.54.65.1
but other subnets is not ping because ospf routing is not runinng
It is interesting that you are able to ping the tunnel interfaces address. Please post the output of these commands on both routers
show ip interface brief
show ip ospf interface
Rick
"ip ospf network non-broadcast" under both tunnel.
please enter this command and send the show ip route.
Hello @samerkareemlo1993 ,
add a tunnel key to each tunnel with different value to help the router understand if the packet is coming from tu1111 or from the point to point tunnel.
This might solve your issue with OSPF om p2p tunnel.
Hope to help
Giuseppe
