GRE Tunnel - Problems
carlosz
I've created an environment based in GRE Tunnels. The idea is force IP packets to pass through a path beetowen a switch that have an IDS to check all packets. My tunnel is used only when the packet is sent by remote router and when this packet returns uses it's normal path. Physically, my remote router and Secondary router don't have an serial interface connected (but my frame-relay network provide and redundancy,in the draw above, I have on remote one serial interface with one IP address. On primary and backup, I have an ATM interface connected to a Frame-Relay network with the same address. My redundacy is provided by a Frame-Relay switch who is responsible to manage the logical links), by this reason, I have to use an GRE tunnel to force my traffic to pass over the switch + IDS. Follow a draw.
/-------------Primary Router
Remote-------\ |
\(Virtual Path) Switch + IDS
\ GRE Tunnel |
\----------Secondary Router
My problem is when my secondary router is down (It's the tunnel's end) my packets try to use tunnel every 60 or 50 seconds that causes a lost of 2 packets.
Everyone knows something about this?
Follow a sample of my configuration:
Remote
interface Loopback0
ip address 192.168.244.29 255.255.255.255
interface Tunnel35
bandwidth 128
ip address 172.16.96.102 255.255.255.252
ip mtu 1514
tunnel source 172.31.62.1
tunnel destination 192.168.244.2
interface Ethernet0
ip address 172.31.62.1 255.255.255.0
no keepalive
interface Serial0
bandwidth 128
no ip address
encapsulation frame-relay IETF
load-interval 30
no fair-queue
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0.1 point-to-point
bandwidth 64
ip address 172.16.192.102 255.255.255.252
frame-relay interface-dlci 16
router eigrp 100
network 172.16.192.102 0.0.0.0
distribute-list 5 in
no auto-summary
eigrp router-id 172.16.96.102
ip route 0.0.0.0 0.0.0.0 Tunnel35
ip route 0.0.0.0 0.0.0.0 Serial0.1 50
access-list 5 permit 192.168.244.2
Primary
router eigrp 100
redistribute ospf 1 metric 10 1000 255 1 1500 route-map OSPF-EIGRP
network 172.16.192.2 0.0.0.0
network 172.16.192.97 0.0.0.0
network 172.16.192.101 0.0.0.0
network 172.16.194.237 0.0.0.0
network 192.168.0.0
no auto-summary
eigrp router-id 192.168.244.1
interface ATM1/0.35 point-to-point
ip address 172.16.192.101 255.255.255.252
pvc 2/75
abr 128 64
broadcast
oam-pvc manage
Secondary
interface Loopback0
ip address 192.168.244.2 255.255.255.255
ip ospf authentication-key 7 120B0C10131D
interface Tunnel35
ip address 172.16.96.101 255.255.255.252
ip mtu 1543
delay 100
tunnel source 192.168.244.2
tunnel destination 172.31.62.1
My routing environment is working, I did some tests to check if my redundancy is activate when the secondary is down and it works perfectly. The tunnel interface is up but the protocol is down. The only problem is when the router try to check the Tunnel interface and turns the protocol on. It try to send some packtes to it (2 packets) and after it is displayed and Recursive problem and the router turn off the tunnel interface. After this all packets is sent to the default route (serial interface). After 50 or 60 seconds this problem occurs again.
I hope that somebody can help me!
Thanks.
Carlos Zen
(5511)8136-1353
carloz@spread.com.br
5 Replies 5
olorunloba
Level 5
Level 5
I think more details of the interfaces might be needed. You did ont give any information concerning the physical interfaces on the secondary router. Also more information on the routing processes.
Though, it seems the problem might be due to recursive routing. Hence check this link.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080087093.html
My physical interface on secondary router is the same of primary (IP Address and Physicall interface), my redundacy is made by a frame-relay switch, so if something is bad, this switch can change the link internally. About the routing process, we use EIGRP to connect remote to the primary router and between the primary and secondary OSPF. In the remote router we have two default route, one to tunnel and another to serial interface with cost of 50. This second route only is applied when the tunnel goes down. It's the time when the problems come, the router try to check if the tunnel is up every 50 or 60 seconds because physically it's up but the protocol is down. I'll try to use a command called "keepalive" to check if the problem is corrected. But this command is only available on some IOS like 12.2.8T which is required more memory and flash. I've to know if is possible to solve this problem without IOS changes. Do you know if is possible to set keepalive or try to check the tunnel state without send some packets to it?
Thanks in advance
I did a test using KEEPALIVE 2 2 command on GRE Tunnel and works very good. I didn't lost any packet and my routing environment made all necessary to send my information to destination. But I still need other opinions because I had to do this in 600 routers and it means costs because this command is only avalilable on 12.2.8T or above. Does anybody knows something about it?
Thanks in advance.
smif101
Level 4
Level 4
The one thing that I see immediatly is that the primary and secondary router doesn't know how to reach the tunnel destination network of 172.31.62.x. I see that you have the loopbacks in eigrp but not the tunnel interface. That will be a problem. Were you even able to ping the remote tunnel interface? Maybe you typed in the configs but I wouldn't set the network statements as you have them, I would but in the subnet mask of the actual interface and not down as a host.
Jason Smith
www.smif101.com
I've theses routes:
Primary
ip route 172.31.62.0 255.255.254.0 ATM1/0.35
ip route 172.31.62.0 255.255.254.0 172.26.0.3 200
Secondary
In EIGRP only my Serial interface on remote and ATM interface on Primary are as network.
The tunnel interface is used only when the remote router send an information, so the backup only receive. This was created because I'll check the information only when the remotes routers send something. This was the project was designed (by the way was designed by other company).
Thanks.
