05-21-2003 01:07 AM - edited 03-02-2019 07:30 AM
Hi guys,
Have a 48 ports module on a 4006. All ports are on the same VLAN and are working fine until today, suddenly some PCs got connection on and off. After checking, realised that the first 12 ports are having the same problem. How can i check whether it's a hardware problem? Did a "sh int" seems fine to me. There are some ports when i plug in the cable, no lights showing the port is connected at all...
05-27-2003 10:52 AM
There is a bug related to this issue . The bug ID is CSCdt80707
05-27-2003 12:05 PM
CSCdt80707 is a CAT OS bug and it appears you have a Sup3/4 and running IOS. Can you let us know what software version you are running?
