Help! Multihoming not working
romeoalvarez
I have 2 offices connected by a T-1 line. One office is unable to receive internet service, so i set up a NAT from one office to the other to allow for internet service to reach the non-internet office. The systems works great, Road Runner ISP provides service to both offices through the NAT. This week QWest DSL is able to provide the non-internet office with DSL Service. I was told i could enable "multihoming" to have 2 ISPs. Can anyone tell me what i would need to do to enable this with my current situation. will i have to reconfigure my routers, 2650 series? I have seen the white paper on this, but it isn't specific as to whether NAT is being implemented for the first time.
klouthan
Hmm, it would be easier if you had a 2651 with two ethernets instead of just one.
What are you currently doing NAT on?
I would connect a DSL router to the modems at both sites and run RIP on both DSL routers and both 2650 routers. If you only have two sites RIP wont be a problem. I would let both DSL routers (like a linksys befsr41 or something cheap like that) do nat and hand out DHCP addresses for their respective sites. This way site 1 uses site 1's internet connection and site 2 uses site 2's internet connection. Not a very good solution, but that is the best I could do with limited info.
Thanks for the response. Let me explain further.
I have to buildings 50 miles apart. I have a T-1 connecting them. Building A is able to receive internet service, building B isn't. So i set up a NAT to feed service from building A to building B, the ISP is Road Runner. Each site has a cisco 2650 router with NAT configured into them so that they can network and share files. Now, QWest has expanded far enough to allow building B to receive DSL service. What i want to do is, keep road runner at buuilding A and at building B have QWest DSL. To do this i was told i should configure the routers to "multihome with auto injection". So my question is, do i need to completly reconfigure my routers to do this or since NAT is already set-up can i just plug in my DSL line.
