Help - Newbie
pm.mcs
I have 4 routers (1st & 2nd leased line) (3rd & 4th connected by ISDN dial up).
Router 1 can access all but the last isdn dialup.
Router 2 can access all
Router 3 can access all
Router 4 can not access 1 or two.
I am using static routes and thought I had put static routes in for everywhere.
Router 2 e.g. (?.?.101.254)& Router 3 (?.?.101.253). Is this where the problem lies as from Router 1 and can ping direct Router 3 but when I tracert to router 4 it stops at Router 2.
Any help would be much appreciated.
Paula
scarothe
Hi Paula:
It would help if you put the configurations for the routers in here.
Thanks...Steve
As requested. Many thanks in advance.
Paula
ROUTER_CAM#show running-config
Building configuration...
Current configuration : 1004 bytes
version 12.2
no parser cache
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname ROUTER_CAM
logging rate-limit console 10 except errors
no logging console
enable secret 5
ip subnet-zero
no ip domain-lookup
no ip dhcp-client network-discovery
interface Ethernet0
description connected to EthernetLAN_1
ip address 200.100.101.254 255.255.255.0
no keepalive
interface Serial0
description connected to Router_Market
ip unnumbered Ethernet0
router rip
version 2
network 200.100.101.0
no auto-summary
ip http server
ip classless
ip route 200.100.100.0 255.255.255.0 Serial0 permanent
ip route 200.100.101.0 255.255.255.0 Ethernet0 permanent
ip route 200.100.104.0 255.255.255.0 Ethernet0 2 permanent
snmp-server community public RO
line con 0
exec-timeout 0 0
password *******
login
stopbits 1
line vty 0 4
password *******
login
end
version 12.2
no parser cache
no service pad
hostname ROUTER_CAM
no logging console
enable secret 5
ip subnet-zero
no ip domain-lookup
interface Ethernet0
no keepalive
interface Serial0
router rip
version 2
no auto-summary
ip http server
ip classless
line con 0
exec-timeout 0 0
password *********
login
stopbits 1
line vty 0 4
password **********
login
end
Router_Market#show running-config
Current configuration:
version 12.0
hostname Router_Market
no logging console
enable password r871uab
ip subnet-zero
no ip domain-lookup
interface Ethernet0
ip address 200.100.100.254 255.255.255.0
no ip directed-broadcast
no keepalive
interface Serial0
description connected to ROUTER_CAM
router rip
version 2
network 200.100.100.0
no auto-summary
ip classless
ip route 200.100.101.0 255.255.255.0 Serial0 permanent
ip route 200.100.104.0 255.255.255.0 Serial0 3 permanent
line con 0
exec-timeout 0 0
password *********
login
transport input none
line vty 0 4
password *********
login
end
ISDN Netgear Routers (Sorry)
Router 3 ip 200.100.101.253 mask 255.255.255.0
static routes
faldlan active destip 200.100.100.0 subnet 255.255.255.0 gateway 200.100.101.254 metric 2
camblan active destip 200.100.101.0 subnet 255.255.255.0 gateway 200.100.101.253
metric 2
dorchlan active destip 200.100.104.0 subnet 255.255.255.0 gateway 200.100.104.254
metric 2
Router 4 ip 200.100.104.254 mask 255.255.255.0
static routes
faldlan active destip 200.100.100.0 subnet 255.255.255.0 gateway 200.100.101.253 metric 4
metric 2
metric 1
allissrcco
Is your ISDN link connected when you tracert to router 4? it sounds like the ISDN interface on router 3 is not up/connected which means the tracert is not crossing router 3 causing your last report to be from router 2. Send me your configs and I'll take a look.
Richard.
Same happens when isdn link is up.
Thanks in advance. Paula
version 12.2
no parser cache
no service pad
hostname ROUTER_CAM
no logging console
enable secret 5
ip subnet-zero
no ip domain-lookup
interface Ethernet0
no keepalive
interface Serial0
router rip
version 2
no auto-summary
ip http server
ip classless
line con 0
exec-timeout 0 0
password *******
login
stopbits 1
line vty 0 4
password *******
login
end
version 12.2
no parser cache
no service pad
hostname ROUTER_CAM
no logging console
enable secret 5
ip subnet-zero
no ip domain-lookup
interface Ethernet0
no keepalive
interface Serial0
router rip
version 2
no auto-summary
ip http server
ip classless
line con 0
exec-timeout 0 0
password *********
login
stopbits 1
line vty 0 4
password **********
login
end
version 12.0
no logging console
ip subnet-zero
no ip domain-lookup
interface Ethernet0
no keepalive
interface Serial0
router rip
version 2
no auto-summary
ip classless
line con 0
exec-timeout 0 0
password *********
login
line vty 0 4
password *********
login
end
static routes
metric 2
metric 2
static routes
metric 2
metric 1
