Help required on VRF
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-02-2006 04:09 PM - edited 03-03-2019 02:05 AM
I am trying to understand how the VRF works. Can someone please advice if the following configuration of the VRFs are correct?
Scenario:
vrf v1 is outside of a FWSM and vrf v2 is inside of a FWSM
Vlan 100 is assigned to the outside interface of the FWSM (100.100.100.2)
Vlan 200 is assigned to the inside interface of the FWSM (200.200.200.2)
VRF v1
ip vrf v1
rd 100:1
interface Vlan100
ip address 100.100.100.1 255.255.255.0
ip vrf forwording v1
interface Vlan110
ip address 110.110.110.1 255.255.255.0
ip route vrf v1 220.220.220.0 255.255.255.0 100.100.100.2
VRF v2
ip vrf v2
rd 200:1
interface Vlan200
ip address 200.200.200.1 255.255.255.0
ip vrf forwording v2
interface Vlan110
ip address 220.220.220.1 255.255.255.0
ip route vrf v2 110.110.110.0 255.255.255.0 200.200.200.2
TIA
PF
- Labels:
Other Networking
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-02-2006 04:39 PM
there are some minor typos and (more important) the order of the commands is not correct. It should read:
ip vrf v1
rd 65000:1
interface Vlan100
ip vrf forwarding v1
interface Vlan110
ip route vrf v1 200.200.200.0 255.255.255.0 100.100.100.2
ip vrf v2
rd 65000:2
interface Vlan200
ip vrf forwarding v2
interface Vlan220
ip route vrf v2 100.100.100.0 255.255.255.0 200.200.200.2
The background is, that the "ip vrf forwarding ..." command will remove an existing IP address from the interface, when applied.
Hope this helps! Please rate all posts.
Regards, Martin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-02-2006 05:58 PM
Martin,
Thanks for the reply. Can you explain why the rd figure have to be
rd 65000:1 and rd 65000:2 instead of
rd 100:1 and rd 200:1 as what I have?
Thanks.
PF
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-02-2006 06:33 PM
there is no strict technical background in your situation. But the RD is only removable by deleting the VRF. You might however find yourself in the situation of peering with MBGP and the full MPLS stuff somewhen down the road. Then 65000 (private AS) is most likely not such a problem compared to 100 (official AS). This said I would use 64578 because everyone (including me ;-) opts for 65000.
It´s more like the question: In case you would implement a brand new IP network, would you start with addressing from 10.0.0.0/8 or from an official IP network like 84.0.0.0/8, which is not yours?
The requirement might not be there, but still I would go for 10/8. Same story with official and private AS.
Regards, Martin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-02-2006 07:19 PM
Martin,
Thanks. I totally understand now. See I didn't think of public/private AS. I just picked a number!! Your help is much appreciated.
PF
