Help to my config, OSPF, DHCP 2596
edinross11
There is something went wrong in my config, but I cant find the problem
THESE ARE MY BASIC CONFIG:
hostname Router1
line console 0
password passwd
login
line vty 0 15
password passwd
login
logging synchronous
enable password passwd
enable secret passwd
service passwod-encryption
banner motd #Only With Access!#
no ip domain-lookup
username admin privilege 15 secret passwd
line vty 0 15
privilege level 15
login local
ip ospf hello-interval 15
ip ospf dead-interval 50
THESE ARE MY DHCP SETTINGS
Is it possible that I missspell something
R1(config)#ip dhcp pool lan1
R1(config-dhcp)#network 192.168.0.0 255.255.255.0
R1(config-dhcp)#default-router 192.168.0.1
R1(config-dhcp)#dns-server 1.2.3.4
R1(config-dhcp)#lease 1 12 30
R1(config-dhcp)#domain-name example.com
R1(config-dhcp)#option 150 ip 192.168.0.1
R1(config)#ip dhcp excluded-address 192.168.0.1 192.168.0.10
 MY OSPF SETTINGS
OSPF protokoll:
router ospf 1
network 192.168.1.0 0.0.0.255 area 0
network 192.168.13.0 0.0.0.255 area 0
router-id 1.1.1.10
passive-interface fa0/1
exit
R1(config-router)#log-adjacency-changes R1(config-router)#network 195.220.123.0 0.0.0.255 area 0
R1(config-router)#router-id 1.1.1.10 R1(config-router)#exit
R1(config-router)#area 0 authentication
R1(config-if)#ip ospf authentication-key PASSWD
R1(config-router)#area 0 authentication message-digest
R1(config-if)#ip ospf message-digest-key 1 md5 PASSWD Router ID R1(config-router)#router-id 200.0.0.1 R1(config-if)#bandwith 115000
R1(config-if)#ip ospf priority 100 R1(config-if)#ip ospf cost 100
___
interface s0/0/0
ip ospf dead-interval 60
ip ospf message-digest-key 1 md5 R1-R2
interface s0/0/1
ip ospf message-digest-key 1 md5 R2-R3
exit
router ospf 1
___
R1#sh ip ospf interface R1#sh ip ospf neighbour [detail] R1#debug ip ospf adj | events
Ospf or telnet not work if you dont specify IP to interface.
