Help with a home lab
papathimiu
I am building a home lab. I have a 1841 router connected to the ISP router and is configured and works good. I have 3550 switch inside my network. I can ping as far as the outside interface on the router, but not further then that. No idea why. I have enabled IP routing on the switch and I have redirected all unknown traffic out of the routers interface. Can anyone suggest something. I have no idea why is not working.  I configure the interface fa0/1 on the router with sub-interface and I used the encapsulation dot1q. On the switch I configured the interface that I have the PC as access and the interface that goes to the router as a trunking. But still the same problem.
Hi ,
  Apply below commands on your router , After that you can ping to any destination from your switch and Host connected to switch .
interface FastEthernet0/0
 ip nat outside
interface FastEthernet0/1
ip nat inside
access-list 1 permit 40.0.0.0 0.255.255.255
ip nat inside source list 1 interface FastEthernet0/0 overload
Sandy
10 Replies 10
Hi ,
  Sub-interface configuration on your router and trunk port configuration on your switch should have proper dot1q encapsulation set .
 If you are using private non-routable IP address for your LAN segement
   ip nat inside (router sub-interface ) & ip nat outside (router wan interface)  must be set on router with corresponding NAT interface overloading your WAN interface .
share your switch & router config
Sandy
Hi SantoshKumar S
I created acces-list extended 101
After I started ip nat source and the interface global
When I try to do it on the interface I got this strange message and the router stoped responding:
*Jun 24 12:33:52.215: %SYS-2-MALLOCFAIL: Memory allocation of 32768 bytes failed from 0x602D2F44, alignment 0
Pool: Processor  Free: 22372  Cause: Not enough free memory
Alternate Pool: None  Free: 0  Cause: No Alternate pool
 -Process= "Exec", ipl= 0, pid= 99,  -Traceback= 0x6029C8CCz 0x602BA054z 0x602D226Cz 0x60F81C78z 0x60F81CF0z 0x60F81D88z 0x60F85704z 0x60FAC2E8z 0x625B2DA8z 0x625B2D8Cz
I have never seen this before
Any Idea why this happened?
Hi ,
     After I started ip nat source and the interface global , what do you mean by global her ?? your WAN interface .
 Kindly share me your router config .
Sandy
Yes. The inteface that is connected to the isp router.
Below is my switch configuration and router configuration:
SW-A#show configuration
Using 2303 out of 393216 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SW-A
enable secret 5 $1$xDZm$LLcViCdbcXDWmPlfk.2VD.
ip subnet-zero
ip routing
no ip domain-lookup
ip domain-name papa.com
spanning-tree mode pvst
 switchport mode dynamic desirable
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
 switchport voice vlan 1
 spanning-tree portfast
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 ip address 40.0.0.2 255.0.0.0
ip default-gateway 40.0.0.1
ip classless
ip route 0.0.0.0 0.0.0.0 40.0.0.1
ip http server
line con 0
line vty 0 4
 password papa
 login
line vty 5 15
 login
end
and router:
Router#show configuration
Using 913 out of 196600 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
archive
 log config
  hidekeys
 ip address 192.168.0.2 255.255.255.0
 duplex auto
 speed auto
 ip address 40.0.0.1 255.0.0.0
 duplex auto
 speed auto
interface Serial0/0/0
 no ip address
 shutdown
 clock rate 2000000
interface Serial0/0/1
 no ip address
 shutdown
 clock rate 2000000
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.0.1
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
 login
scheduler allocate 20000 1000
end
Thank you
Hi ,
 ip nat outside
ip nat inside
Sandy
Thank you.
I will try this as soon as I go home. i just got at work.
What I dont understand is why the router give me the above error when i try to enable nat on the global interface. At the interface connected to wan. I had to restart the router because it was not taking any commands anymore.
Thanks again.
I think my router has a problem. I dont think is the configuration. I try what you sad up and this is what happened:
Router(config-if)#ip nat outside
% NBAR ERROR: due to memory problem, parsing stopped
% NBAR Error : Activation failed due to insufficient dynamic memory
% NBAR Error: Stile could not add protocol node
%NAT: Error activating CNBAR on the interface FastEthernet0/0
Router(config-if)#
*Jun 25 02:50:08.192: %SYS-2-MALLOCFAIL: Memory allocation of 10260 bytes failed from 0x6246BDC0, alignment 0
Pool: Processor  Free: 54504  Cause: Memory fragmentation
 -Process= "Exec", ipl= 0, pid= 3,  -Traceback= 0x6029C8CCz 0x602B57A8z 0x631414B4z 0x6246B468z 0x6246B5CCz 0x6244680Cz 0x624468E4z 0x624469E0z 0x62446884z 0x624469E0z 0x62446884z 0x624469E0z 0x62447548z 0x6247FC0Cz 0x6248AC50z 0x62476FC4z
*Jun 25 02:50:08.196: %NBAR-2-NOMEMORY: No memory available for StILE lmalloc,  -Traceback= 0x6246B490z 0x6246B5CCz 0x6244680Cz 0x624468E4z 0x624469E0z 0x62446884z 0x624469E0z 0x62446884z 0x624469E0z 0x62447548z 0x6247FC0Cz 0x6248AC50z 0x62476FC4z 0x62496338z 0x624966D0z 0x6170DC78z
*Jun 25 02:50:08.664: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up$gon 2
I will try the same in another router. I have 2811 and I wil do it in a moment and let you know what hapened
I did configure NAT in a new router. If i connect the pc straight to the routers fa0/1 interface, everything works perfect. But when I connected through the switch, nothing works.
Any suggestions please?
Hi ,
  Are you using straight cable between your router & switch ?? if so use cross cable old model router and switch dont have auto MDIX
check following thing
1) from the switch ping locally the IP address assigned for Vlan 1 40.0.0.2
2) From the host ping to switch VLAN IP address 40.0.0.2
3) From the switch see you are able to switch host MAC address and arp table
if all three statement matches , then check for speed & duplex settings from router to switch ensure both side are same . After fine tuning speed & duplex settings if it doesnt work then you need to change it cross cable .
Sandy
I am sorry I had to time to log in here and update my post. Tha problem was my routers memory. I update the IOS and everything is good now. Thank you Santosh
