Help with Blade environment - WS-CBS3020-HPQ
smith606306
  I have 2 Cisco WS-CBS3020-HPQ blade switches in the server farm and each one has a seperate trunk link to the core switch.
Which ports do i use to connect them internally across the backplane?
Marwan ALshawi
i think you need to review the design before connecting them using a backdoor link as this could lead to layer 2 loop or spanning tree if not configured correctly could lead to suboptimal layer 2 path
Marwan ALshawi
OK thanks.
Do you have a link to a design document on the best setup for them
I think this might help
http://www.cisco.com/en/US/prod/collateral/switches/ps6746/ps8742/ps8764/white_paper_c07-443792.pdf
If helpful rate
