08-24-2022 04:55 PM - edited 08-08-2023 03:55 PM
Hi!
I have a Cisco 7600 and recently experimented high CPU utilization.
Thanks in advance.
08-25-2022 01:22 PM
--> RM-MTY-01 uptime is 3 years, 29 weeks, 3 days, 7 hours, 46 minutes
A 'simple' reboot (preferably after hours) might resolve this. An uptime of >3 years can lead to all sorts of issues...
08-25-2022 01:43 PM
Thanks for your comments. What do you mean "preferably after hours"?
So, you think a reboot is enough to face this problem? Don't you think we are facing a bug?
08-25-2022 01:53 PM
with 'after hours' I mean, after hopefully nobody needs connectivity through this router...possibly at night.
A very long uptime can lead to memory exhaustion a.o. I would schedule a reboot and check if the problem persists.
08-25-2022 04:04 PM - edited 08-03-2023 11:14 AM
08-26-2022 12:02 AM
the lines below (obviously) indicate that there are problems with the HSRP group, physical interface, and OSPF adjacency. It is hard to tell if these problems are caused by the high CPU, but that is very well possible.
Aug 23 13:04:59.392: %LDP-5-NBRCHG: LDP Neighbor 207.248.231.243:0 (4) is DOWN (Discovery Hello Hold Timer expired)
Aug 23 13:05:02.396: %HSRP-5-STATECHANGE: Vlan10 Grp 253 state Standby -> Active
Aug 23 13:05:03.784: %HSRP-5-STATECHANGE: Vlan10 Grp 253 state Active -> Speak
Aug 23 13:05:15.384: %HSRP-5-STATECHANGE: Vlan10 Grp 253 state Speak -> Standby
Aug 23 13:05:18.336: %LDP-5-NBRCHG: LDP Neighbor 207.248.231.243:0 (3) is UP
Aug 23 13:05:30.716: %OSPF-5-ADJCHG: Process 1000, Nbr 201.151.25.14 on Vlan100 from LOADING to FULL, Loading Done
Aug 23 13:09:17.802: %LDP-5-NBRCHG: LDP Neighbor 207.248.231.243:0 (3) is DOWN (Discovery Hello Hold Timer expired)
Aug 23 13:09:31.831: %LDP-5-NBRCHG: LDP Neighbor 207.248.231.243:0 (3) is UP
Aug 23 13:10:34.547: %LINK-3-UPDOWN: Interface GigabitEthernet2/36, changed state to down
Aug 23 13:10:35.531: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/36, changed state to down
Aug 23 13:10:36.523: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/36, changed state to up
