Hostname not resolving on clients
joelcote
Hello All,
I recently setup DHCP on my 7200 router and that works great. The client machine picks up an address and works fine. The problem is is that I cannot surf the internet. If I browse using IP address instead of hostnames, I can pull up sites. Can't do it with hostnames though..was wondering if anyone had any ideas...
Thanks in advance..
dbellaze
Level 4
Level 4
I would just verify that your clients are getting the proper DNS settings. If they are, then make sure your 7200 or another device isn't filtering DNS.
Daniel
thisisshanky
Level 11
Level 11
Looks like a DNS issue or may be some ACL blockign your DNS requests. Are you using external DNS or internal ? Are you able to ping the DNS servers. Are the DNS servers part of your IP add pool used in DHCP ???
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
