How a Cisco device locates and loads IOS
zillah2004
Cisco says :
"The default source for Cisco IOS software depends on the hardware platform. Most routers use the boot system commands saved in NVRAM. Cisco IOS software allows several alternatives to be used. Other sources can be specified for the software, or the router can use its own fallback sequence to load the software."
My understanding to what cisco says, that :
"Most routers use the boot system commands saved in NVRAM."
What happend if we erase startup ?
We are not going to see the boot system command in the "show startup-config" command ?
Do we need to rely on Cisco IOS to boot first from Flash then tftp , then ROM ?
MARCELO MATURO
With the config-register you can modify the boot options.
Regards.
Marcelo
