How do I get IGMP enable on 6509 port/interface?
jkeeffe
Level 2
Level 2
6509 IOS ver. = 2.2(17a)SX3
The 6509 ports g2/1-12 are in vlan1 and are switch ports. IGMP shows as enabled at the vlan interface but not the port/interface.
interface GigabitEthernet2/1
description link to 49.128 subnet via 1924/B
no ip address
speed 100
duplex full
switchport
switchport mode access
interface Vlan1
ip address 164.72.49.131 255.255.255.128
ip pim sparse-dense-mode
end
ENGLAB-6513-Native#sh int status
Port Name Status Vlan Duplex Speed Type
Gi2/1 link to 49.128 connected 1 full 100 10/100/1000BaseT
IGMP shows up on the vlan, but not on the interfaces themselves:
ENGLAB-6513-Native#sh ip igmp int vlan1
Vlan1 is up, line protocol is up
Internet address is 164.72.49.131/25
IGMP is enabled on interface
Current IGMP host version is 2
Current IGMP router version is 2
IGMP query interval is 60 seconds
IGMP querier timeout is 120 seconds
IGMP max query response time is 10 seconds
Last member query count is 2
Last member query response interval is 1000 ms
Inbound IGMP access group is not set
IGMP activity: 7 joins, 5 leaves
Multicast routing is enabled on interface
Multicast TTL threshold is 0
Multicast designated router (DR) is 164.72.49.133
IGMP querying router is 164.72.49.129
Multicast groups joined by this system (number of users):
224.0.1.40(1) 224.0.1.39(1)
IGMP snooping is globally enabled
IGMP snooping is enabled on this interface
IGMP snooping fast-leave is disabled and querier is disabled
IGMP snooping explicit-tracking is enabled on this interface
IGMP snooping last member query interval on this interface is 1000 ms
ENGLAB-6513-Native#sh ip igmp int g2/1
GigabitEthernet2/1 is up, line protocol is up
Internet protocol processing disabled
IGMP is disabled on interface
Multicast routing is disabled on interface
No multicast groups joined by this system
1. How do I enable IGMP at the interface/port level?
Prashanth Krishnappa
IGMP snooping is enabled by default on switchports. If it is disabled in your switch you can enable it using global command "ip igmp snooping"
sh ip igmp int g2/1 shows as IGMP disabled because it is a layer 2 port. If it were a routed port and you had an IP address and PIM enabled, you would have seen it as enabled.
